November 26, 2024, 12:23:49 PM *
Author Topic: Handbrake warning light  (Read 5502 times)
hongkongphooey
« on: November 17, 2010, 08:27:48 PM »
Is it supposed to flash through the indicator relay?
MattNoVAT
France France
« Reply #1 on: November 17, 2010, 08:32:39 PM »
Hi,
Yes it should - although when mine failed I had to use a Delta indicator relay so it no longer flashes!
1981 2000 Coupe S2/FL
1976 1600 Coupe S1
2007 Ypsilon 1.3 Bi-Colori
thecolonel
« Reply #2 on: November 17, 2010, 08:56:41 PM »
Up under/ to the right of the the steering column there should be a two pin flasher unit,
small silver/alloy can (just over 1 inch diameter).
This is the handbrake flasher unit (does not normally use the standard indicator or Haz unit)
the unit runs at about 2w , anything greater and there would not be enough draw to flash the lamp.
Geoff
hongkongphooey
« Reply #3 on: November 17, 2010, 09:42:43 PM »
God,it's so annoying! What with that and the 50 switch positions for the headlamps! Roll Eyes
Thanks  Smiley
« Reply #4 on: November 26, 2010, 07:18:51 PM »
Hong Kong
I re-wired mine without the flasher so it just lit the light as it drove me mad as well!
cheeky monkey
« Reply #5 on: November 26, 2010, 10:13:40 PM »
disconnected my hazard warning light.  the indicators have been better since
Graham
1979 beta coupe 1300
hongkongphooey
« Reply #6 on: November 27, 2010, 04:51:51 PM »
I'm glad i'm not the only one it annoys! Might have to by-pass it then....My indicators aren't the best either so hopefully it'll help them too!
cheeky monkey
« Reply #7 on: November 27, 2010, 06:57:42 PM »
by the way, i meant the handbrake warning light not the hazard. You soon get used to not hearing or seeing the warning light flashing.
Graham
