November 23, 2024, 11:24:05 AM *
Pages: [1] 2
Author Topic: Wheel.......bearings  (Read 17761 times)
hongkongphooey
« on: February 16, 2010, 10:50:27 AM »
Are rear wheel bearings still available? My search fu is letting me down  Smiley
thecolonel
« Reply #1 on: February 16, 2010, 03:37:49 PM »
Yes, listed in www.lanciabetaparts.co.uk  parts section
lanciamad
Marcus Robinson
« Reply #2 on: February 16, 2010, 08:17:44 PM »
Same bearing for the fronts.
2001 - Honda Civic Type R EP3
hongkongphooey
« Reply #3 on: February 16, 2010, 09:35:05 PM »
Ah yes,thanks. I didn't notice that hiding behind the Montecarlo  Grin
HFStuart mentioned a complicated securing system for them....any tips for getting the old hub off and changing the bearing?
thecolonel
« Reply #4 on: February 16, 2010, 09:44:53 PM »
haven't got a pic of a Beta one but:-
http://cgi.ebay.co.uk/lancia-gamma-front-wheel-bearing-lock-ring_W0QQitemZ390122445742QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item5ad51c1bae
usually bearings come with securing nut, but if not I've a couple of new ones
I use the old nut reversed to knock the shaft out of the hub. there should be
a couple of drift holes in the back of the mounting so you can knock the old
bearing off.
Geoff
Geoff
« Last Edit: February 16, 2010, 09:48:57 PM by thecolonel » Logged
TonyLanciaBeta
« Reply #5 on: February 16, 2010, 10:55:54 PM »
just enabled the search feature on the parts page,
Betaboyz also does the locking ring for the Beta
http://betaboyz.myzen.co.uk/cart/index.php?main_page=advanced_search_result&search_in_description=1&keyword=wheel+bearing
1981 Beta Coupe 1600
2012 Ypsilon (daily)
hongkongphooey
« Reply #6 on: February 16, 2010, 11:47:57 PM »
Cheers guys  Smiley
markwast
« Reply #7 on: February 17, 2010, 01:24:40 AM »
Hi, and i do have the tool to remove the locking ring too so you dont muller the old one.......
LanciaBetaParts
TonyLanciaBeta
« Reply #8 on: February 17, 2010, 10:31:02 PM »
this is the tool, mine was very tight even using a long breaker bar
« Reply #9 on: February 17, 2010, 10:52:51 PM »
You see what I mean Simon - everybody else in the world uses a circlip !
If you're chucking the bearing anyway I guess you could use a bit of heat / freeze spray to help the nut out.
thecolonel
« Reply #10 on: February 17, 2010, 11:09:35 PM »
Tony,
hope you remembered to tap in the indentation first.......
me, I use a cold chisel as I always replace the ring anyway
mind you I still remove/replace bearings with a couple of
large sockets and a big hammer
last time I did the fronts I fitted them in a spare pair of hubs,
unfortunately they were both right hand side ones  Roll Eyes
Geoff
hongkongphooey
« Reply #11 on: February 18, 2010, 08:45:34 AM »
I see what you mean....that's a pita isn't it!
I'll say it again,it's much easier working on Japanese cars!  Tongue
« Reply #12 on: February 18, 2010, 10:09:39 AM »
Geoff
LOL. Genius !
We've all been there with a 'I didn't just do that, did I ?' type of moment.
Stuart
lanciamad
Marcus Robinson
« Reply #13 on: February 18, 2010, 11:18:44 AM »
Quote
I've done one using a vice before but I think that beats me Cheesy
Must admit I just used a couple of punches and a decent hammer to remove the retaining ring.
Is the tool available to buy and cheaply Huh?
« Reply #14 on: February 18, 2010, 02:22:19 PM »
Yes it's available  - they come up on fleabay every so often
No it's not particularly cheap at about £50. Probably better to borrow one from Mark or indeed me !
thirdbrother3
« Reply #15 on: May 16, 2010, 05:59:35 PM »
just fighting one of these lock rings on a rear hub. can i just confirm with someone that they are standard thread (ie. not left handed thread). would hate to be putting all this effort into tightening it!
thirdbrother3
« Reply #16 on: May 17, 2010, 04:30:55 PM »
sorted. just needed a little heat!
« Reply #17 on: January 08, 2011, 12:28:09 PM »
I'm sure most on here probably already knew but something I've realised the beta wheel bearing is not only the same as some Fiat X1/9 but also fits numerous Renaults!! you might have to buy a kit and discard the Renault mounting hardware but that does make obtaining bearings so much easier check out FAG part number 562398a for the bearing on its own
http://region47.com/upload/FAG%20Radlager%20PKW%202009.pdf
but of course new old stock bearing kits on ebay is the place to be
« Reply #18 on: January 08, 2011, 01:22:37 PM »
Would anyone have the measurements for the 'business end' of the wheel bearing tool, or better still an engineering drawing? It shouldn't be too hard to get something like that made up by a local machine shop...
« Reply #19 on: January 08, 2011, 01:26:43 PM »
I can have a look but TBH most folks simply improvise and get away with it, just don't use a chisell and a lump hammer like back street garages  Shocked
Pages: [1] 2
