January 07, 2025, 12:05:50 PM *
Author Topic: Fast indicators but not hazards  (Read 259 times)
JohnFol
« on: January 01, 2025, 11:06:44 PM »
Evening all,
I have fitted rear LED indicator bulbs and now have a strange symptom.
If I indicate left or right, they all flash twice as fast. Typically that means a bulb has gone but all working. I'm guessing it's because the load is less due to the led bulb.
However hazard lights work perfectly.
I'd like to stick with moving over to LEDs but need to understand why hazards work and indicators don't, ie is changing the relay a possible solution?
neromoto
Japan Japan
« Reply #1 on: January 02, 2025, 02:58:38 AM »
Is there an indicator relay and a hazard relay attached to each? This means that two relays are fitted.
The one for the hazard may be an LED-compatible relay.
Replacing the relay for the indicators with an IC relay would solve the problem.
I have replaced all indicator bulbs with LEDs and the relays with IC relays.
Thema 8.32 S2 1990
Gamma Berlina S1 1978
Gamma Coupe S2 1982
Beta HPE S2 1976
Flaminia Coupe 1960
« Reply #2 on: January 02, 2025, 11:50:29 AM »
Hi John
You must have an LED specific Flasher Relay. Try Classic Car LED for decent items. They have produced a full kit for the Monte and the bulbs are obviously better quality than the ebay offerings. I am loving the dash bulb replacements that fit perfectly in the shallow factory blue domes. For the first time ever I have to consider a matching dimmer to replace the OE Rheostat that will not work with LEDs.
JohnFol
« Reply #3 on: January 02, 2025, 02:16:45 PM »
Thanks both for the replies. I might swap out the original relays as a precautionary measure.
« Reply #4 on: January 02, 2025, 09:35:58 PM »
Hi John
Above is 100% correct, after changing all my indicators for leds, the original hazard relay works fine and had to replace the side indicator for modern led compatible one, simple fix.
JohnFol
« Reply #5 on: January 02, 2025, 10:43:57 PM »
I'm being a bit lazy.
Is the flasher unit in fuse box or in car?
« Reply #6 on: January 03, 2025, 07:15:03 PM »
Hi John,
From the factory it was attached to the steering column in a steel clip.
Most are now hanging.
Mine was a 3 pin round unit, but they vary.
