December 23, 2024, 02:26:32 PM *
Author Topic: Cleaner Warm Intake Hose  (Read 376 times)
Rpat29
Newbie
« on: November 26, 2024, 03:35:25 PM »
My Air intake hose is old, torn and come away from the engine. see photos
Can anyone advise on a replacement hose and where to obtain one?
Also, is it okay to still drive with the hose disconnected for short distance to my local garage
Nigel
« Reply #1 on: November 26, 2024, 10:33:54 PM »
Hi,
That pipe is to feed warm air to the carb, mostly during colder weather. It is not essential
for engine health nor normal running. My car doesn't even have one, nor did it ever, as it was
delivered to Australia originally.
You can remove it. You won't notice any difference.
However, your air filter container will have a vacuum valve on the side. Just make sure, by looking
into the intake port,( the one from the plastic shroud) that the flap is positioned to allow cool air flow from the
front. That's its default position anyway so all should be good.
If you wish to keep up appearances later, I've seen various aluminium pipes on ebay of suitable diameter.
Nigel
The past:
Kevo
Full Member
England England
« Reply #2 on: November 27, 2024, 11:23:13 AM »
I think I got my aluminium ducting from Car Builder Solutions.
1979 Beta Coupe 1600
1972 Triumph TR6 Pi
2005 BMW Z4 Roadster
Rpat29
Newbie
« Reply #3 on: November 27, 2024, 04:39:26 PM »
Thanks Nigel. That's really great advice and will check t ensure the valve is in the correct position.
Thanks Kevo on where to get the hose if I need to
Clifford3051
Full Member
« Reply #4 on: November 27, 2024, 05:49:10 PM »
Gates do this hose and it's readily available in the UK. Measure the diameter of your current one to make sure it fits.
C
