Yes
Hello lancialulu.
You i assume are looking for the fuel pump / petrol vapour pump relays and the fuel regulator which you call an interlock?
If memory serves the relays are located under that rubber flap that covers the ignition coil on the passenger side. They are to the left of the coil and there is a also a double fuse holder under a plastic cover - you can't miss them as they are the only relays on a (standard UK VX) in that location. Its been years since i have looked at my VX but i am sure that is where they are located.
The clunk you hear when you turn the ignition on is the electrovalve which controls fuel pressure. It is located on a bracket along with another fuse next to the power steering reservoir. The most common fault is one of the fuses melt or don't make proper contact in the twin fuse box.
The fuel pump is energised on cranking of the engine and then the oil switch relay takes over otherwise you would have to crank for ages. The round engine multi plug is where the power takeoff is located below the distributor. The big red wire in the middle is Siamesed and goes to energise the pump on cranking.
Whats the actual problem you are trying to debug?
