November 21, 2024, 05:51:59 PM *
Pages: 1 [2] 3
Author Topic: Engine makes noise after overhaul  (Read 2657 times)
Gerke123
Netherlands Netherlands
« Reply #20 on: August 21, 2024, 08:55:07 AM »
To me it sounds like something simply not set up right have you tried moving the distributor whilst it is running to see if it gets smoother?
Yes, I tried this but there was no immediate change
Lancia Beta Coupé 1975 2.0 (Finished early june, 2022)
Triumph Burlington Arrow
Volkswagen Beetle
Opel Rekord A (sold)
2022 Mazda CX-5
2005 Ford Fiesta ST
Gerke123
« Reply #21 on: August 21, 2024, 09:01:41 AM »
I agree that valve clearances are likely not correctly set and frankly if your mechanic can not do that job I would worry about the rest of the work. Set stone cold spark plugs out by using the tappet depression tool one at a time after using a syringe to remove the excess oil. You obviously measure first with feeler gauges looking for 0.40mm inlet and 0.45mm exhaust clearances. The Haynes Beta Manual tells you how, but you need a decent stock of shims to replace those note the right size. Avoid shims smaller than 3.50mm to prevent cam damage. If you have saved shims from previous engines you probably have lots of 4.20mm! Note always measure the shim thickness with a decent digital vernier or micrometer. to check the actual size and never use shims with heat bluing or surface scuffing.
Good luck.
I took some measurements on the exhaust side. the first cylinder is at 0.50, 2, 3 and 4 have difficulty reaching 0.30........
I will see if I can obtain the special tool somewhere in the Netherlands.
It's a shame about the three hours of work the technician put into this.
-Gerke
Volkswagen Beetle
2022 Mazda CX-5
2005 Ford Fiesta ST
« Reply #22 on: August 21, 2024, 08:58:51 PM »
It is not a shame, I would tell him where to get off and not bother using him, never mind asking for my money back…….
Hopefully it has not caused any long term damage. Time to check the inlet side.
You should be able to find the tool easily, here is one advertised for Fiat 124 in Germany (same twin cam engine) but should be widely available at around 50 Euros.
https://shop.wum-autoteile.de/Valve-adjustment-tool-Fiat-124
« Last Edit: August 24, 2024, 11:49:13 AM by peteracs » Logged
Gerke123
« Reply #23 on: August 23, 2024, 08:53:42 AM »
It is not a shame, I would tell him where to get off and no bother using him, never mind asking for my money back…….
Hi,
The man from the garage comes to check the valve clearance in around 1-2 weeks time. He wants a chance to correct his mistake and I think I should give him that chance.
Thank you so far and I will keep you informed.
-Gerke
« Last Edit: August 25, 2024, 04:06:29 PM by Gerke123 » Logged
Volkswagen Beetle
2022 Mazda CX-5
2005 Ford Fiesta ST
Gerke123
« Reply #24 on: August 26, 2024, 07:12:22 PM »
Hi,
Today I spoke with the man who overhauled the rotating part of the engine, so not the guy who did the valves. He advised to check the oil for aluminum particles in the bearings. The oil was clean and clear so this is not the case. He said that if the valves are too tight you should not hear a ticking sound, only if they are too wide......anyone have experience with this?
Gerke-
Volkswagen Beetle
2022 Mazda CX-5
2005 Ford Fiesta ST
« Reply #25 on: August 26, 2024, 10:49:50 PM »
In theory, yes, too wide gap will result in a noise, which is the cam hitting the shim on the steep part of the cam, ie instead of ‘gently’ reducing the gap. However if too small a gap maybe it is falling foul of something else?
Also you only posted the exhaust side, not the inlet side values?
I recently visited a fellow Spider owner who has a long knowledge of these engines and he had a chat many years ago with a Lancia factory mechanic whose comment was that the engines work best if you can hear the tappets, ie gap them on the loose side of the spec. This is purely anecdotal, so make of it what you will…..
Gerke123
« Reply #26 on: August 27, 2024, 06:07:43 PM »
Hi,
I took some more time and now come to the following measurements.
E1 0.20 E2 0.15 E3 0.20 E4 0.20 now the inlet.
I1 0.15 I2 0.25 I3 0.20 I4 0.25
What it should be E 0.45 - 0.51 and the inlet 0.39 - 0.45
there is a difference......
Volkswagen Beetle
2022 Mazda CX-5
2005 Ford Fiesta ST
« Reply #27 on: August 27, 2024, 07:36:12 PM »
Yes, not good. Hope you can get it sorted out correctly.
« Reply #28 on: August 29, 2024, 12:48:07 PM »
It seems unlikley that the clearances being 0.2mm too small would produce so much noise but I hope it turns out to be something simple.
Gerke123
« Reply #29 on: September 10, 2024, 05:09:10 PM »
Hi,
The mechanic at the garage has now adjusted the valves correctly and unfortunately the noise is still there.
I'm going to take the engine, subframe and all, out again. I don't know anything else either.
According to the mechanic, the noise is louder at the bottom of the engine than at the top.
Gerke-
Volkswagen Beetle
2022 Mazda CX-5
2005 Ford Fiesta ST
« Reply #30 on: September 10, 2024, 05:35:27 PM »
Hi Gerke,
When you have the sump off check if number 2 conrod is hitting the fuel pump lobe on the Auxillary shaft. The Aux Shaft has to be precisely positioned at TDC or it will hit eventually breaking the conrod and punching a hole in the block. If you no longer use a manual fuel pump it is common to cut off the fuel pump drive lobe and insert a plug into the oilway after careful cleaning. With this done there is no need for precise timing of the Aux Shaft. How to do this is explained in Guy Crofts workshop manuals.
Of course if your mechanic sets the shaft in the right place it does not hit the con rod.
Otherwise look for a loose oil pump or oil drain pipe hitting the crank. After that it becomes poor assembly or incorrect bearing sizes.
Unfortunately I have now seen these things too often from engine builders who should find other work!
PS with a bore scope you can inspect each cylinder through the spark plug hole looking for strike marks on the pistons from the valves. If standard pistons have been re-used which is rarely a good idea then the wrong size class in the wrong bore will create piston slap which is noisy. OE Size classes are stamped on the crank case sump join for each bore at the factory and detailed in GCs books.
« Reply #31 on: September 10, 2024, 08:22:02 PM »
Hi Eric
Good call on the aux shaft, that may very well explain it.
« Reply #32 on: September 11, 2024, 10:29:21 AM »
Hi Eric
Easy to check visually if the pulley is in the right position without taking anything apart
Gerke123
« Reply #33 on: September 11, 2024, 05:08:54 PM »
Hi Eric,
This is a photo of the setting before installation. Visually it seems to be going well. I did use a different axle than the one that came out, but visually there was no difference.
Volkswagen Beetle
2022 Mazda CX-5
2005 Ford Fiesta ST
stableblock
« Reply #34 on: September 11, 2024, 05:24:06 PM »
Its hard to see from the pic but looks like you could be a tooth out on the aux shaft.  Certainly worth a closer look, dont adjust and run the engine unless you are sure.  It should turn over by hand cleanly with the correct timing of the aux shaft but it might be hard to detect if there is only marginal contact.
« Reply #35 on: September 11, 2024, 08:03:41 PM »
The belt is not fitted correctly.
The teeth are not located on the left side of the aux pulley.
If this was run like this then is quite likely the timing moved.
The belt would be also be under tensioned as soon as the teeth slip into place and unlikely to stay correctly timed.
I hope this was adjusted before installation.
« Reply #36 on: September 11, 2024, 08:27:01 PM »
Hi Eric
It's also what I suggested two weeks ago Smiley
« Reply #37 on: September 11, 2024, 08:30:48 PM »
What Ian (Squiggly Wiggly) Said I agree with.
stableblock
« Reply #38 on: September 12, 2024, 08:51:06 AM »
Good spot from the pic. Might need a new tensioner spring too.
Gerke123
« Reply #39 on: September 12, 2024, 03:13:33 PM »
hi to all,
This photo is taken before i turned the engine by hand, and all teeth were neatly in place after turning. I'm going to dismantle the engine in the coming weeks and will check the aux shaft first.
I'll keep you informed.
Gerke-
« Last Edit: September 12, 2024, 04:37:31 PM by Gerke123 » Logged
Volkswagen Beetle
2022 Mazda CX-5
2005 Ford Fiesta ST
Pages: 1 [2] 3
