February 02, 2025, 05:46:15 AM *
Author Topic: No Spark - Please Help!  (Read 1434 times)
spyder_resto
Simon
« on: June 30, 2024, 10:22:03 PM »
Hi Everyone
Apologies if this has been asked but I could not see an answer in previous posts and I am scratching my head.
My Beta Spider 2.0 is turning over but will not start.
Here is what I have done so far:
- ignition switch work does work and turns engine over.
- checked I have power at the metal connector attached to body that has wires connected to coil
- have power to coil at the coil terminals with small nuts where wires are connected
- new HT leads
- new ignition coil
- new rotor arm and distributor cap
Engine turns over quickly but will not start!
Car is being started after a long time and even with Easy Start does not start up.
I have used a spark plug tester and getting no spark on any cylinder.
Any thoughts or advice would be welcomed!
Many thanks
Simon
« Reply #1 on: June 30, 2024, 10:40:06 PM »
Electronic or points distributor?
spyder_resto
Simon
« Reply #2 on: July 01, 2024, 07:47:35 AM »
Electronic distributor
thanks
Si
Ammy
« Reply #3 on: July 01, 2024, 08:25:00 AM »
I had a similar problem on my Spider, only intermittent. After much frustration, I found the L.T. lead to the distributor had a break in the insulation where it entered the distributor body, probably from constant rubbing. Very difficult to see !!!!!!!!!!!
« Reply #4 on: July 01, 2024, 10:02:40 AM »
Faulty electronic ignition unit?
JohnFol
« Reply #5 on: July 01, 2024, 11:45:45 AM »
Did you replace all of those parts as a way of diagnosing an existing fault? If it worked before then you have the option of substituting parts back in, i.e. go back to original coil, try original cap . .
Also thinking if you disconnect the HT between coil and distributor (at the cap end) you could place the exposed connection near the engine block and look for it arcing when you crank. Might help identify if it's LT / HT vs something distributor onwards...
« Last Edit: July 01, 2024, 11:49:02 AM by JohnFol » Logged
stableblock
« Reply #6 on: July 01, 2024, 04:12:44 PM »
I would check the connections on the ballast resistor if you have one.  These seem prone to failure.
millieman
« Reply #7 on: July 02, 2024, 01:11:48 AM »
Change the coil, some new coils just don't work.
« Reply #8 on: July 02, 2024, 07:52:59 AM »
If you have a ballast resistor you will need the 1.5 Ohm coil, not the 2.5 one from memory, however surprised you do not get any spark due to that.
JohnFol
« Reply #9 on: July 10, 2024, 07:56:39 PM »
Hi Simon, how is the diagnosis going?
spyder_resto
Simon
« Reply #10 on: July 13, 2024, 06:02:43 AM »
hi Everyone
Thanks for the replies.
I bought the coil from Mark at Betaboyz as well as cap and rotor arm so i am pretty sure they are all the right parts.
We did swap new parts back to the old ones but there was no difference.
Speaking to H& H ignition and few other people i think the only two remaining possibilities are the ignition unit or distributor so I am planning to take those both off and give them to H&H ignition for diagnosis and repair as necessary.
We will see where we are after that.
Plan is to get parts of car  this week so I will update in due course.,
thanks
Si
