November 21, 2024, 03:58:56 PM *
Author Topic: HELP Looking for engine head bolts.  (Read 1533 times)
tenio hf
Bulgaria Bulgaria
« on: January 06, 2024, 09:33:05 PM »
Hello.
The same is 1585 cubic meters. 101 hp
I believe the same ones are for replacement, but I'm having trouble finding them.
If anyone can help I would be very grateful.
Thanks in advance.
[img]https://pichost.name/images/2024/01/06/20240102_11490963798f1303c491bf.md.jpeg[/i
Alfa Romeo Grosswagon q4
Lancia Prizma Integrale
Lancia Beta Coupe 1.6
Lancia Beta Coupe 2.0 IE
Fiat 124 Sport Coupe 1.4 AC
Fiat Bravo HGT
Fiat Uno 45 Fire
Avo 250 Tourist
Jawa 350 Kalifornia
« Reply #1 on: January 07, 2024, 06:04:29 AM »
Just bought a set for a 2 Litre from Mark at Betabyz. They're hex head ones though and whilst he might not be showing stock it's worth seeing an email to see if he has any?
https://353652584127257704.weebly.com/store/p604/Torx_Headbolt_Set.html
Fiat Panda 100HP and now!
tenio hf
Bulgaria Bulgaria
« Reply #2 on: January 07, 2024, 08:36:50 AM »
Thanks=
Fiat Bravo HGT
Fiat Uno 45 Fire
Avo 250 Tourist
Jawa 350 Kalifornia
« Reply #3 on: January 07, 2024, 10:31:45 PM »
You can use the later type stretch bolts with the ribe type heads, easier to obtain I think they are the same on Delta but please check carefully as it's a while since I bought mine. I've never seen any with torx heads as on the link to Mark's page, only ribe, which requires a different tool fitting.
« Last Edit: January 07, 2024, 10:37:53 PM by rossocorsa » Logged
tenio hf
Bulgaria Bulgaria
« Reply #4 on: January 08, 2024, 06:01:51 PM »
The dimensions of the bolt are 115 mm long. including the head, diameter 10 mm., thread 1.25 mm., steel not less than R 10.
Fiat Bravo HGT
Fiat Uno 45 Fire
Avo 250 Tourist
Jawa 350 Kalifornia
« Reply #5 on: January 09, 2024, 03:03:33 PM »
Which part of the head are you taking about? Is it the cam carrier?
tenio hf
Bulgaria Bulgaria
« Reply #6 on: January 09, 2024, 05:15:57 PM »
This is the bolt that secures the engine head to the engine block, there are 10 bolts.
Fiat Bravo HGT
Fiat Uno 45 Fire
Avo 250 Tourist
Jawa 350 Kalifornia
« Reply #7 on: January 09, 2024, 11:25:57 PM »
https://m.autodoc.co.uk/ajusa/382915
I am not 100% sure so please check carefully but I think these are correct. They have the later bolt head style with ribe type pattern (very good as it gives a really secure grip of the tool when torquing up).  They are stretch type bolts so require the late type beta torquing sequence. You may also need new washers. If you don't have the correct tool you would need to buy a set of ribe bits, not normally expensive.
« Reply #8 on: January 10, 2024, 12:59:03 PM »
Try Aecar, not expensive.
https://www.aecar.co.uk/products/cylinder-head-bolt-fiat-lancia-twin-cam
tenio hf
Bulgaria Bulgaria
« Reply #9 on: January 11, 2024, 04:20:35 PM »
Thanks everyone for the advice and guidance, I took from these bolts, the only difference being the head.
Fiat Bravo HGT
Fiat Uno 45 Fire
Avo 250 Tourist
Jawa 350 Kalifornia
