January 30, 2025, 03:28:42 AM *
Author Topic: Inlet valve needed.  (Read 1913 times)
simplydelboy
« on: June 08, 2023, 10:51:53 AM »
Somewhat bizarrely after an engine rebuild no. 1 inlet valve bent during startup. Can’t see any other damage and don’t know what caused it. Has anyone got a spare? Head diameter is 42mm so it’s the later series. Thanks in advance,
Del
1977 Beta Spyder 2000
1983 Beta HPE 2000ie
Previously. Beta Sedan, Spiders, HPEs, Fulvias, Gammas, Flavias, Thema 832
JohnFol
« Reply #1 on: June 08, 2023, 11:13:33 AM »
Hi Del, I've used these guys for a few engine bits, and they list inlet valves. Might be worth a check..
https://www.aecar.co.uk/products/inlet-valve-fiat-lancia-twin-cam-4255694?_pos=25&_sid=4447ce872&_ss=r
simplydelboy
« Reply #2 on: June 08, 2023, 01:01:19 PM »
Hi John, thanks so much for the info. I’ve left a message with them and hope they have the valve. Betaboyz sadly out of stock. Bloody annoying as the rebuild went so well until this issue. Ah well, cars!!!
« Reply #3 on: June 08, 2023, 01:57:16 PM »
I have some spare heads complete and can take a valve out if you want to use a used one?
simplydelboy
« Reply #4 on: June 08, 2023, 04:10:56 PM »
Hi Peter, yes a used one is no problem, I’ll just lap it in. If it’s not a lot of trouble. Let me know the cost, thanks,
Del
« Reply #5 on: June 08, 2023, 06:56:51 PM »
Hi Del
Not a problem, I will have a look at my heads tomorrow and get back to you.
simplydelboy
« Reply #6 on: June 08, 2023, 08:28:55 PM »
Thanks Peter.
« Reply #7 on: June 09, 2023, 08:57:55 AM »
I take it you cambelt was fitted correctly Derek? One tooth out can bend a valve.
simplydelboy
« Reply #8 on: June 09, 2023, 03:10:02 PM »
Hi Neil, see my email. I’m sure we set it ok. Tried to put a pic on this reply but couldn’t get it to work.
simplydelboy
« Reply #9 on: June 09, 2023, 03:11:14 PM »
I see it did work!! It wasn’t on the preview so I assumed it hadn’t worked!!
« Reply #10 on: June 09, 2023, 04:03:12 PM »
Hi Axel
Please send your address via messages and I will get a couple out to you.
