December 03, 2024, 08:07:15 PM *
Author Topic: 2000ie Coupe dipstick tube  (Read 1210 times)
Dogsbody
« on: January 01, 2023, 04:56:34 PM »
Hi there . Is the long dipstick tube on ie models removable? It's held by a nut and bolt at its top end but looks as if it should just pull out of the gearbox at the bottom. Is this a correct assumption?
Thanks, Dave.
Online Online
« Reply #1 on: January 01, 2023, 06:19:40 PM »
If it's the same as a Volumex one then yes, I think there's a rubber O ring around the tube. Try undoing the top fixing nut and seeing if you can get some rotation at the bottom of the tube where it enters the gearbox casing. If you can then it'll pull out but try not to bend it!
Fiat Panda 100HP and now!
« Reply #2 on: January 01, 2023, 09:02:41 PM »
Yes it is the same on VX and IE, I took one out of an IE box and fitted to the VX box I have which was missing one.
The fitting for the earlier boxes does not fit the IE/VX box
« Last Edit: January 02, 2023, 06:07:41 PM by peteracs » Logged
Dogsbody
« Reply #3 on: January 02, 2023, 05:49:11 PM »
Thanks for the confirmation. I didn't want to try too hard until I was sure what I was dealing with. I definitely don't want to bend it!
Cheers, David.
