November 25, 2024, 12:56:27 AM *
Author Topic: Strut Bodies  (Read 8302 times)
lanciamad
England England
Marcus Robinson
« on: October 08, 2009, 10:21:09 AM »
Could anyone tell me the length between the spring platform and the base of the rear strut body on a beta coupe Huh?
I'm hoping there is no difference between this length and the HPE, and they differ only in the legth of tube between the spring platform upwards Huh?
2001 - Honda Civic Type R EP3
« Reply #1 on: October 08, 2009, 11:46:09 PM »
I'm fairly sure I've seen them fitted to an hpe or at least the strut top mount not sure which /i have a pair of coupe konis off the car so will measure if I get chance but a bit busy at the moment with other things to get in the garage
lanciamad
England England
Marcus Robinson
« Reply #2 on: October 09, 2009, 08:38:52 PM »
I think the figure i'm hoping for is around the 405mm mark.
« Reply #3 on: October 11, 2009, 04:58:03 PM »
lanciamad
England England
Marcus Robinson
« Reply #4 on: October 12, 2009, 10:09:09 AM »
Thanks for that rossocorsa  Wink Possible project for the future.
hongkongphooey
« Reply #5 on: February 03, 2010, 10:43:03 AM »
To clarify.....does the HPE or the Coupe have the longer rear strut.
One thread seems to suggest it's the coupe with the longer one,yet the pic on this thread of the coupe strut looks like the shorter one.
I've got one of each on mine Roll Eyes
hongkongphooey
« Reply #6 on: February 11, 2010, 08:33:53 PM »
Well as no-one else wants to.....i'll clarify for myself.
It's definately the HPE with the longer strut.  Wink
bravo-v8
« Reply #7 on: February 12, 2010, 05:05:43 PM »
You're right the rear strut from the HPE are the same as the Berlina and Trevi, coupe and spyder have shorter one. At the front Berlina and Trevi have the longer one and HPE, Coupe ans Spyder shorter one.
« Reply #8 on: February 21, 2010, 12:35:48 PM »
My 'suspect' rear strut is shorter than the good one that I was fairly sure was original. Also doesn't the coupe sit higher than the HPE/Trevi at the back? The strut turrets on the coupe certainly intrude into the boot more than in the HPE/Trevi. Still confused.
« Reply #9 on: February 21, 2010, 03:00:04 PM »
that might be an illusion the coupé is a fair bit lower than an HPE or Trevi
as you can see (sorry quickly taken photo!) length from the upper bottom mounting bolt to the top of the body should be about 560mm on a coupé and 606mm on an HPE ignore that I think the tech data is confusing!! but I still think the coupe strut is shorter
« Last Edit: February 21, 2010, 03:14:12 PM by rossocorsa » Logged
lanciamad
England England
Marcus Robinson
« Reply #10 on: February 21, 2010, 08:00:39 PM »
The strut itself I would say is shorter, as the inserts are shorter for coupe's than the HPE's. Whether it sits higher at the back compared to a HPE I wouldn't like to say. Who's got standard suspension and a tape measure? Wink
lanciamad
England England
Marcus Robinson
« Reply #11 on: February 21, 2010, 08:09:53 PM »
Don't think there's much in it, if anything i'd say the coupe sits slightly lower.
HPE...
http://www.flickr.com/photos/lanciamad/3543278784/#in/set-72157618420523632/
Coupe...
http://www.flickr.com/photos/lanciamad/3913059392/#in/set-72157622347634740/
http://www.flickr.com/photos/lanciamad/1196763327/#in/set-72157601587896850/
http://www.flickr.com/photos/lanciamad/1201057161/#in/set-72157601593408866/
markwast
« Reply #12 on: February 24, 2010, 09:02:56 PM »
The strut bodies are different between Coupe/spider and HPE/Saloon/Trevi ones.
Length from the bottom of the spring platform on all models are the same, but length above the platform is different. HPE Etc has a longer body overall.
Sealed units are also shorter than insertable ones.
The springs in the HPE are also are longer  than that of the coupe but virtuallty identical to the saloon/trevi. Ride height is almost the same across the range.
If you put coupe springs and struts in a saloon you will lower the ride height, the position of the strut (f&R) top is higher on the saloon . (therefore the same as the rear HPE).
LanciaDave
United States United States
« Reply #13 on: August 06, 2010, 07:28:07 PM »
Mark Wastnidge wrote:
"If you put coupe springs and struts in a saloon you will lower the ride height, the position of the strut (f&R) top is higher on the saloon . (therefore the same as the rear HPE)."
Has anyone out there done this? Interesting to lower sedan ride height, but wondering about effect on ride and handling. I fear it may not be as sporting or stiff, as coupe's are lighter cars. Just brewing up ideas here.... real world feedback appreciated.
Thanks,
Dave Decker
a 'couple' Betas
Woodburn, OR., USA
Dave
Wilds of the Pacific NW, USA
77 HPE 1.8L manual steering
77 Sedan 2L FI
84 HPE Vx
76 Scorpion (Montecarlo) 2L w/dual 40DCNF
« Reply #14 on: August 07, 2010, 02:30:51 PM »
never seen it done however I suspect you might have suspension travel issues I think the main reason for the different struts is to take account of the fact that you actually can get an adult into the seats in an HPE or Berlina!
