November 30, 2024, 11:34:52 AM *
Author Topic: Alternator bracket bush  (Read 2155 times)
squiglyzigly
« on: October 12, 2021, 10:22:30 PM »
Now the Berlina is in regular use it’s to be expected that a few niggles will show up on a 42 year old car.
Today I decided to address the failed alternator bracket bush using a polyurethane replacement.
It wasn’t a straight fit as chose to use a universal anti-roll bar bush.  It only took an hour to make what I hope will be a long term solution.
First I set about putting a waist in the bush with the help of the pillar drill, an angle grinder and a file.
squiglyzigly
« Reply #1 on: October 12, 2021, 10:27:45 PM »
Then I made the hole in the bracket larger. My intention is that a larger diameter bush should last longer so I removed metal from the meaty part of the bracket (blue zone) to avoid the thin end from becoming weaker.
squiglyzigly
« Reply #2 on: October 12, 2021, 10:30:29 PM »
Then slip in the bush.  Suits you sir.
Job done.
« Reply #3 on: October 13, 2021, 07:02:49 AM »
Tidy re-usable solution. Nice!
« Reply #4 on: October 13, 2021, 08:29:59 AM »
Hi Ian
As Eric says a nice solution and could be applied elsewhere for cracked and degraded rubber bushes.
mangocrazy
Graham Stewart
« Reply #5 on: October 13, 2021, 01:27:56 PM »
Nice one, Ian. That's particulalrly timely as I hope to be fitting the alternator to my engine in the near(ish) future and something like that is a fine idea. I also notice that you are a fellow owner of a Mercury Startrite pillar drill! I recently refurbished mine and it's a properly meaty piece of kit (over 90kg by my estimation).
2002 VW Transporter T4
2017 KTM Duke 690R
2008 Aprilia SL1000 Falco
1992 Ducati 888 SP3
1988 Honda VFR750F
1980 Yamaha RD350LC
squiglyzigly
« Reply #6 on: October 13, 2021, 05:11:26 PM »
Yes the Mercury is made to last and takes 2 too lift it on the bench. It’s even a struggle to extend it on your own.
Mine came from a school clearout many years ago and I must say its a lovely made piece. Something very pleasurable about changing the speed by moving the belt up and down the pulleys.
Old school like the car, cough cough . . . And me  Embarrassed
mangocrazy
Graham Stewart
« Reply #7 on: October 13, 2021, 07:02:37 PM »
I had to break mine down to its component parts to get it on the bench. My wife and I just managed to get the column and base onto the bench and then built it up from there.
I use a scissor jack and block of wood under the table to make it easier to raise and lower the table precisely.
You and me both... Wink Mine was an ebay purchase about 10 years ago.
2017 KTM Duke 690R
1992 Ducati 888 SP3
1988 Honda VFR750F
1980 Yamaha RD350LC
