November 23, 2024, 11:07:20 AM *
Author Topic: Tyre pressures ?  (Read 2054 times)
« on: August 18, 2021, 02:25:36 PM »
Hi All
Given that the new tyres will have different construction to old ones, any suggestions where I start with the new tyres on the car, they are the 175/70R14.
The user manual suggests around 25psi, which in today’s world is possibly low, but given the car weighs a lot less than most cars today may be sensible?
betabuoy
« Reply #1 on: August 18, 2021, 04:05:22 PM »
Hi Peter,
25 is too low. I’d go for 30 psi.
1967 Morris Minor Traveller
1925 Austin 7 Chummy
« Reply #2 on: August 18, 2021, 04:47:40 PM »
Running my Berlina 185/65/14 @ 32psi f/r Toyo proxies. seems to work wet dry and all surfaces.
VX coupe 195/55/15 @ 32f 30r.
I think modern tyres are somewhat different in compound, construction and design to move away from old pressure settings.
The tyres will have max recommended pressure at load stated on the sidewall, just stay under that and have a play to see what you prefer is my best advice. Its free to play and every day is a learning day.
« Last Edit: August 19, 2021, 07:53:47 AM by squiglyzigly » Logged
« Reply #3 on: August 18, 2021, 05:57:50 PM »
Hi All
Thanks for the suggestions, I will probably start around 30 and see how it all feels. Getting used to the car in first place is going to be a challenge in itself.
Kevo
« Reply #4 on: August 19, 2021, 08:49:13 AM »
I robbed this off another forum and find it very useful.
Tyre Pressure 4 psi rule.
Use the recommended pressure on your tyre placard/manual as a start point, drive for approximately one hour, stop and check the pressure. If it’s gone up by 4psi then your pressures are spot on. This is most unlikely on your first attempt!! So, if they have gone up by more than 4psi, your start pressure was too low. If it has gone up by less than 4psi, then your start pressure was too high. Adjust your pressures by 2psi in the appropriate direction and this will become your starting points for the next cold start.
Cheers Kev.
1979 Beta Coupe 1600
1972 Triumph TR6 Pi
2005 BMW Z4 Roadster
« Reply #5 on: August 19, 2021, 09:02:27 AM »
Hi Kev
Thanks, will give it a go, though driving for an hour in the short term will be a challenge. Also I would imagine the type of driving makes a difference?
Kevo
« Reply #6 on: August 19, 2021, 11:12:06 AM »
Hi Kev
As long as you get some good heat into the tyres, time is not so important. Just drive it like you stole it.
Kev
  Grin
« Last Edit: August 19, 2021, 11:14:03 AM by Kevo » Logged
1972 Triumph TR6 Pi
