Hi Mark,
I took the easy option and fitted it as below but it is used with a Facet Silver Top electric pump at the back.
Hi Chris
I'm just getting round to fitting my Filter King, which oddly came with no instructions, just a sheet expounding it's many advantages. I can see from your picture that the horizontal take off feeds the carbs, but what is the purpose of the T piece that you have fitted between the filter and carbs?
Also, is the filter set to an optimum pressure out of the box, or did you adjust it at all?
Cheers, Neil
