November 25, 2024, 06:49:47 AM *
Author Topic: Filter King Regulator  (Read 2462 times)
smithymc
« on: May 09, 2021, 06:40:11 PM »
I have one of these taking up shelf space so thought I would fit it, as a period modification.
The question is- where should I put it and how to mount it? Polite answers only.
Mark
jreacock
England England
« Reply #1 on: May 09, 2021, 09:06:54 PM »
Hi - I put mine as shown in the pic. There were a couple of holes already in the side of the bay, that I picked up on with the angle.
Seems fine. I have an electric fuel pump in the boot, and an inertia cut-off switch - just in case.
69 Fulvia 1.6HF S1
71 Works Fulvia 1.6HF
75 Gp4 Stratos HF
81 Beta Spyder 2.0
82 037 Rally stradale
« Reply #2 on: May 10, 2021, 06:58:50 AM »
Will the Filter King work OK with the manual pump that I imagine is fitted to Mark's car? I've often thought of fitting one, but don't want to go electric.
smithymc
« Reply #3 on: May 10, 2021, 08:14:12 AM »
I used to use them on pushrod Fords in the 80s, with mechanical pumps I would have thought.
betabuoy
« Reply #4 on: May 10, 2021, 06:45:34 PM »
Hi Mark,
I took the easy option and fitted it as below but it is used with a Facet Silver Top electric pump at the back.
1967 Morris Minor Traveller
1925 Austin 7 Chummy
GerardJPC
« Reply #5 on: June 21, 2021, 04:38:38 AM »
I have been having repeated difficulties with fuel contamination, and fuel filters are living short but cheerful lives in my Beta.  I shall try a second flush of the tank, but am also getting a Filter King fitted.  I have one in my Leyland Princess and it seems a good device.
1979 Beta 1600 Coupe
1962 Lancia Appia Series 3 Berlina
1973 Fiat 124 Sport Coupe 1800
1973 Lancia 2000 HF Coupe
1981 Lotus Eclat Series 2
1981 Yamaha YB 100
1982 Moto Guzzi V50 Monza
1983 Land Rover Series 3 88
2005 Alfa Romeo 156 Crosswagon Q4
2009 Jaguar XK Coupe 5.0
« Reply #6 on: September 18, 2021, 10:48:39 AM »
Hi Mark,
Hi Chris
I'm just getting round to fitting my Filter King, which oddly came with no instructions, just a sheet expounding it's many advantages. I can see from your picture that the horizontal take off feeds the carbs, but what is the purpose of the T piece that you have fitted between the filter and carbs?
Also, is the filter set to an optimum pressure out of the box, or did you adjust it at all?
Cheers, Neil
« Reply #7 on: September 18, 2021, 11:18:49 AM »
Hi Neil
Pre-empting Chris, but suspect it is fuel return to tank. I guess this means the pump is running all the time, but does keep the fuel recycling which helps prevents vapourisation maybe?
mangocrazy
Graham Stewart
« Reply #8 on: September 19, 2021, 06:05:19 PM »
Hi Mark,
Hi Chris,
Very nice engine bay! What air filtration are you using? Is it one of the Monte Hospital's airboxes? If so, I will need to pick your brains at some point as I'm planning on doing the same. If not, what is it?
Graham
2002 VW Transporter T4
2017 KTM Duke 690R
2008 Aprilia SL1000 Falco
1992 Ducati 888 SP3
1988 Honda VFR750F
1980 Yamaha RD350LC
betabuoy
« Reply #9 on: September 19, 2021, 11:44:52 PM »
Chaps,
Thanks Peter, spot on. T piece is to the fuel return.
Graham, Air box is fibreglass and from a Holbay Hillman Hunter. A mate of mine with a Fulvia tipped me off on that one. Fits very nicely and saved a lot of fabricating.
