Hiya,
as you may have read on the members cars, I have a new project 1980 s2 coupe without keys. I've got the code to try my luck with getting new door keys, but the ignition is another matter.
I've not taken apart an ignition switch before, and this one came to me part disassembled - column shrouds off, outer bit of the ignition switch itself off and able to turn the barrel with a screwdriver in the lock.
Ignition switches appear to be hard to find at the moment - I say that, I need to confirm if my car is a 5 wire one or a 4 wire one.. but in the meantime I thought I'd take a crack at repairing this one.
I've been able to remove the bit with the barrel and it's surrounding casing off the car
With the goal of trying to remove the barrel itself to replace it. I removed a small screw from one side to get it off the car, the other side had that err. dowel pin arrangement, which I've drilled out, but the barrel is still not moving - tried it in all positions. What's next?
ps. I would make a terrible car thief
