November 25, 2024, 06:23:18 PM *
Author Topic: fuse meltdown!  (Read 1835 times)
jimincov
« on: November 23, 2020, 07:15:07 PM »
I hate these fuses!
i ran my heater blower for afew minutes flat out to try and dry out the carpet after a heater water leak (turns out the matrix / heater valve leaks if slider set to cold!) with the following results... Im guessing the motor is drawing more current than normal.... thinking about disconnecting the heater plumbing and getting the matrix & blower motor out for inspection.
gotta clean up that fuse box now..
keeps me off the streets!
« Reply #1 on: November 23, 2020, 07:27:33 PM »
Definitely wiring issues there with huge resistance. Check the wiring throughout the circuit.
Also buy some modern relays because vintage parts in this area is trouble you do not need.
Good Luck
jreacock
« Reply #2 on: November 24, 2020, 01:12:35 PM »
Didn't actually blow the fuse though. Maybe check the resistance of the parallel resistor in the pic against what it should be. I believe that this is in parallel with the heater motor, so you need to disconnect the wires to measure it. Take a pic first.
69 Fulvia 1.6HF S1
71 Works Fulvia 1.6HF
75 Gp4 Stratos HF
81 Beta Spyder 2.0
82 037 Rally stradale
