November 21, 2024, 07:28:59 PM *
Pages: 1 ... 6 7 [8]
Author Topic: My 1.6 coupe restoration (formerly back in red + rust)  (Read 22199 times)
chrisc
« Reply #140 on: July 11, 2023, 10:33:56 AM »
Doh moment from the weekend.. right, whats left to attach to the exterior - ah, the washer jets.
Washer jets mounted, lets just connect up the.. wheres the pipe gone? wait, wheres the tank gone???
I despair at points.. the car has come back bizarrely with the washer pump, but not the tank it was attached to.
How much pain am I going to be in for retrofitting either the VX style tank or a bag tank?
Current:
S2FL Coupe 1600 (restoration project)
Former Lancias
HPE VX A52 VGK (parts donor)
C363 RPC (probably still sorned in cumbria with it's new owner)
« Reply #141 on: July 11, 2023, 11:49:40 AM »
Hi Chris
VX style scuttle tank will need some fixings unless you have them in the scuttle already. The bag option is similar, but just needs two small hooks. They are also available new for little money with integral pump, but do not hold as much fluid.
Routing the wiring should be easier for a bag tank as you could locate where the original tank went.
Obviously getting an original for you car is the simpler option.
chrisc
« Reply #142 on: August 03, 2023, 01:10:24 PM »
Time and weather continues to be against me, but some more progress.
Merlin motorsport provided complete washer kit for £30 (bag, pump, tubing, wiring, jets, switch) which strikes me as a bargain even if I only needed half of it. That went in without needing to modify anything
Also fitted the battery isolator, and set about trying to figure out why it wouldn't run since changing the fuel filter.
By some miracle, I watched a tv show featuring the logical fallacy 'post hoc ergo propter hoc' - Since event Y followed event X, event Y must have been caused by event X, and had that in mind.
How can a fuel filter change short of putting it in back to front, stop fuel from getting to the engine? it can't.. so thankfully I followed a sensible diagnostic process and discovered that lack of fuel at the carb was caused by lack of fuel in the tank Smiley so it's running again.
Now that it's running again with the exterior together, it's take out the dashboard and find the water leak. Watch this space..
Current:
Former Lancias
chrisc
« Reply #143 on: August 06, 2023, 12:09:00 PM »
So after all these trim and presentation jobs it's finally time to tackle the water leaks. Probably been putting it off because it's depressing finding bonus rust, but here we are
Minor miracle that this instrument cluster is still working! corrosion central
Dash out. I removed the old insulation on the firewall after this.
And over in the n/s a-pillar where the worst of the rot on the car was I find this
Bit of poking later and chipping off some butyl and it looks like this
It looks horrific, and of course it should have been fixed when the car was done, but that's split milk, under the bridge. At least it's accessible to fix, and the holes above it that led to it have been fixed.
So what does this mean for our water leak mystery?
Well, there's a small leak over in this ghastly mess in the corner, but the main culprit, whatever it is, is behind the heater box. Of course it's behind the bloody heater box, anything else would be simple!
Taking a break and will regroup on it this pm
Current:
Former Lancias
Nigel
« Reply #144 on: August 06, 2023, 01:36:47 PM »
Chris, that's certainly unwelcome.
The heater box is only held in by the 4x 6mm nuts in the scuttle, so fairly
easy to remove.
A bit more stripping will be needed before welding.
Is that a wavy vertical crack I see, or something else?
Nigel
The past:
chrisc
« Reply #145 on: August 06, 2023, 02:29:59 PM »
easy to remove.
Nigel
Thanks Smiley it's more just the annoyance of draining coolant if that's required which I assume it is.
The suspicious looking bit is just flaking butyl.
Having embarked to the garden for some manual labour which requires less subtlety than a beta (unless there are jobs on the car best handled with a pickaxe / mattock) I had a question for the forum..
With the heater box air inlet in the scuttle, some rain must get into even when the cars where new, where is that supposed to go? wondering if that might be to blame with mine
Current:
Former Lancias
« Reply #146 on: August 06, 2023, 02:45:12 PM »
Hi Chris
First up, the water coming in via the bonnet vents should be diverted either side of the heater inlet and the inlet has a lip around it, the water should drain out via two drain holes in the scuttle into the engine bay, these holes should have rubber ‘hoses’ on them. The scuttle is also shaped so that water should not get into the side vents.
On your newly found rot, that is where the front chassis support comes into the cabin and needs to be properly repaired. On my HPE it had similar (worse) rot in that area and when we removed the front subframe you could move the front of the car up and down relative to the cabin. I suggest you also check the other side to see if that also has an issue. Definitely not a welcome sight and you need to check in the engine bay as well where it comes through.
Nigel
« Reply #147 on: August 06, 2023, 04:56:52 PM »
Chris,
There is also a drain at the base of the heater unit.
The connecting hose goes through the bottom of the firewall.
Nigel
The past:
chrisc
« Reply #148 on: August 06, 2023, 05:57:36 PM »
Well. the main leak is solved, and like most things, I should have looked at it sooner.
This bracket wasn't reattached after the car was painted. Water down windscreen = water into the hole where the attaching bolt should have gone. Drips through right onto the lip of the heater inlet, and the seal is missing. Presto, water in cabin.
As simple as reaffixing that central bracket with the appropriate stainless nut + bolt and presto. Water buggers off to the sides and drains as it should, not a drop through into the cabin itself.
I figure I'll just make a new seal on the vent as it looks pretty generic, but for now, I'm really glad to not be taking apart the heater, and not having another enormous rust hole to solve.
Current:
Former Lancias
chrisc
« Reply #149 on: August 20, 2023, 07:28:15 PM »
More tiny progress whilst waiting for availability for garage to do the further welding.
Decided I didn't want to go on a mission every time I want to buy wiper blades. Whilst I'm sure there are betas out there with standard arms, rather than the side pin affair mine had, I couldn't find them easily, so as a temporary solution I fitted a pair of the worlds most terrible looking adapters.
On which note, wiper arms are made out of serious stuff, and drill bits are even more variable in quality than I thought.. lidl cobalt drill bits.. yes but incredibly slow. bosch drill bits.. nope. Random B&Q set I got given years ago with a house purchase, ok.
Current:
Former Lancias
chrisc
« Reply #150 on: September 08, 2023, 09:54:57 PM »
After this weeks visit from the Sahara to the UK the car was looking almost barn find condition!
A hasty scrub and dropped off at a trusted local garage to tackle the further rot
Not pictured is a pancake air filter and crankcase breather filter fitted to a) give me room to access the carb adjustment screws during tweaking, and b) to keep filtered air available whilst I clean up the original housing.
I've blocked off some vacuum lines in the process which will undoubtedly reveal to me what purpose they serve at some point!
Current:
Former Lancias
chrisc
« Reply #151 on: October 20, 2023, 08:42:05 PM »
Popped down to see progress today. utterly failed to take pictures.
The work that's been done to that nasty rot is amazing. it went quite far, back of the wheel well beyond it too.
Little hole in the left rear suspension turret has been a gift that keeps on giving. Patch on a patch on a patch all taken out to be made good.
The real surprise however has come from a small floorpan hole at the edge behind the drivers seat. In uncovering that it ended up in a peel back pristine looking underseal to reveal that the floorpan is shot where it meets the sills, on both sides.
Fortunately they are happy to continue, the guy is a proper craftsman and the rates are very fair!
Current:
Former Lancias
« Reply #152 on: October 20, 2023, 10:00:09 PM »
Hi Chris
These problems are pretty common, especially looking at the original rot where water would come into the cabin. Glad you have found someone to do the work who seems to know what he is doing.
chrisc
« Reply #153 on: March 05, 2024, 06:01:36 PM »
So.. a long overdue update
If we recall, it went in for a nasty bunch of rust on the passenger side chassis leg, a 20p sized hole in the inner n/s/r suspension tower, and a hole in the floorpan beneath the driver seat.
Chassis leg
Driver side floorpan
and.. brace yourselves
the 20p sized hole
And with that, the car was perfect and lived happily ever after.. I wish.
More rust has been exposed
So on with that, question really is will we have to drop the subframe out to get at it - if so, stand by for scope creep with a new gasket set for the engine, a new clutch and who knows what else!
Current:
Former Lancias
« Reply #154 on: March 05, 2024, 06:30:38 PM »
That's ugly. Cut it out and put new steel in, it's the only way!
Fiat Panda 100HP and now!
« Reply #155 on: March 05, 2024, 07:12:14 PM »
Hi Chris
Sadly not uncommon problems, just glad you are able to see a way forward. It will be worth it in the end, just very painful getting there. Given how far you have come, hope you can see it to the end.
Online Online
« Reply #156 on: March 05, 2024, 10:53:58 PM »
Hi Chris
Well done for getting it done. You will know you have a great car that is safe and solid to enjoy. BTW I just wrote an article for the Monte Consortium on Scope Creep or whilst I am here as my Montecarlo Clutch change job spins off into multiple other must fix areas!
« Reply #157 on: March 08, 2024, 05:45:05 PM »
Bottom of the A pillar. I feel your pain, it's a complex area to repair but very strong indeed once done.
