Amazingly I managed to fail to take any overall pictures today, just detailed ones.
It's really the simplest things I struggle with sometimes! today was actually mostly dominated by one simple problem - how to move a car with properly seized brakes.
I pushed the old girl out of the garage just a tad.. tried pushing it back to make sure I wouldn't need any help, and discovered that whilst I had pushed it out, I couldn't push it back.
I then discovered that my mate who I had prepared for just such an eventuality had been offered some short notice building work and was unavailable, and the wife was.. unwilling to volunteer.
On a nicer day I would have jacked it up and taken the brakes off, but it was bloody miserable outside today, so once I'd given it a scrub and a hoover I grabbed the battery from my alfa, disconnected the coil lead and drove her back in on the starter. Or at least I tried - the starter got me most of the way but couldn't hack the combination of the garage lip for the front wheels and the seized brakes. Being a gambler I hooked up the coil lead, took a deep breath and turned the key.
For a car running on 23 year old petrol she runs absolutely lovely and even in the few seconds taken to reverse her in the garage she's got a noticeably different character from the VX's I've had in the past - much more zingy.
So what did I actually do whilst it was out of the garage.
I gave it a clean, vacuum and filled in my little inspection sheet
I also found the key code where you'd said it would be, which is excellent.
Tony - this is all that was left of the dealer sticker at the base of the rear window
Lets get the bad bits out of the way before I get onto the good bits. This isn't all the rust but it's the bits that I'll focus on for today.
The passenger side door is drooping after all, hence the poor alignment.
I'm not sure if this grot alone is sufficient to be responsible for that - but it's not going to help.
I also had a look at what the situation at the base of the o/s front wing where we suspected there'd be more rot - yup
Noticed some flaky paint in the boot drain channel above the rear light. That turned out to be particularly yucky.
And really the largest single area - below the rear window turned out to be more extensive than I'd thought - basically that whole lower edge is frilly
Possibly also a small amount of grot on the front crossmember but I'll get a look at that when I take the valance off.
Now, before the doomsayers come out... Lets get onto some good.
- The front wings need nothing but normal panel prep + painting
- The rear quarters need nothing but normal panel prep + painting
- The doors I think will get by with just the smallest amount of attention to the interior bottom edge where the panels fold over
- The bonnet interior and top lip are both better than they looked
- The boot lid needs nothing but normal panel prep + painting
- The sills are good
- The glass is all good
- The floor pans are good - I poked at some flaky underseal and it peeled away to reveal the unmarked factory red paint!
- It starts, runs and drives!
Next stop online shopping. Hopefully most of it will be simple but i'll mention the bits I think will be trickier so if anyone knows a supplier for the following shout
- Headlamps + bezels
- Lancia key blanks
- Boot badges (beta + 1600)
- Stainless trim for the boot lid
Thankfully the expansion of Beta Boyz means a lot of the stuff that would have been a nightmare is now relatively simple, not least all those repair panels!
