November 23, 2024, 09:15:23 PM *
Author Topic: Front seat belts for Spyder  (Read 5190 times)
JohnFol
« on: September 25, 2020, 05:02:23 PM »
Afternoon all, aiming to swap out the front belts for new ones and would like a second opinion. Aiming to avoid imports / ebay and go for something IVA approved such as this https://www.carbuilder.com/uk/securon-retractable-seat-belt-long-stalk-buckle-black
I'm more than capable of fitting but less confident choosing the right parts! Has anyone fitted these, or similar?
« Reply #1 on: September 25, 2020, 06:21:51 PM »
Hi John,
Appearance suggests this would work, although I would prefer a fixed stalk rather
than the floppy cable-ended type I have on my HPE.
Although they passed the MOT, mine are surely past their best,and very sticky/slow to retract properly.
It's a reasonable price,and I've had other stuff from them,they post quickly.
JohnFol
« Reply #2 on: September 25, 2020, 09:54:47 PM »
Thanks Nigel. Just need to check length of current belt and will order. They also sell switch gear that is same size as Lancia so double order.
« Reply #3 on: September 26, 2020, 10:19:39 AM »
I think these along with 3 point non inertia rears are what I am using on my Beta Spider. Expect to re-use Bolts and spacers for a neat fitting and you might want to buy new bolts as posted by Peter. These lack the sprung offset bit intended to stop rear seat passengers tripping, but that was overkill IMHO and I would rather not have rotting seat belts!
JohnFol
« Reply #4 on: September 26, 2020, 10:45:34 PM »
Eric, were you able to send a link to how you did the rears? If I'm taking back seats / panels out (again) I might fit all 4 in one go.
fred2660
Belgium Belgium
« Reply #5 on: September 29, 2020, 01:15:28 PM »
Ordered the front ones. Will post when fitted
JohnFol
« Reply #6 on: September 29, 2020, 06:36:24 PM »
That would be fab!
« Reply #7 on: September 30, 2020, 04:34:30 PM »
Hi John
Just go to the Pictures I posted in Members Cars and you can see the new upper mounts and the Ford Focus Isofix I had put in.
Enjoy
« Reply #8 on: November 24, 2020, 06:33:04 PM »
Hi JohnFol and fred2660 and others.....
Do you guys have an update on the Car Builder front seatbelts?
Nige
JohnFol
« Reply #9 on: November 25, 2020, 02:29:21 PM »
Hi Nige, aspirations to get them fitted took bit of a back seat as gear linkage still not aligned properly. Also have a few other bits to be doing like steering gaiter, bottom door trim, fitting central locking . ..!
Will keep you posted but nothing to report as yet
« Reply #10 on: April 24, 2021, 06:05:24 PM »
I ended up buying a belt set from Universal Seat Belts on Ebay.
It comes with a 150mm solid female end.
After i'd established that it works on my HPE, I ordered another for the pax side.
Each belt was around £23.00.
There is one downside.....you loose the spring device and stiff end that holds it to the floor
which is normal OE to ease rear pax access.
fred2660
Belgium Belgium
« Reply #11 on: April 26, 2021, 10:41:00 AM »
After a long winter break I went back to the garage....they fit!!
JohnFol
« Reply #12 on: April 26, 2021, 01:51:53 PM »
Which ones did you buy?
fred2660
Belgium Belgium
« Reply #13 on: April 26, 2021, 03:29:01 PM »
These one
