November 30, 2024, 11:42:11 AM *
Pages: [1] 2
Author Topic: Another Newbie  (Read 7614 times)
icedmunkie
« on: September 01, 2009, 01:23:56 PM »
I picked up a Lancia Beta HPE this weekend, which I got given as a project.
I have no history with working on Lancia's at all but have rebuilt a few land rovers before, so at least thats a start!
The car runs and stops and has a clutch which is a bonus and it seems all there although there are a few pipes and stuff missing.
Bodywork is fair with a couple of really rotten bits such as drivers side sill from the door to the back wheel totaly gone, Bonnet has seen better days too. Most of the rust is bubble spots as far as I can tell.
I have no clue where to start yet on this project but going to give it my best shot, at least its more practice for work as I am still an apprentice mechanic although been working on cars now for about 7 years Roll Eyes
Where would anybody suggest as a good starting point on one of these?
« Reply #1 on: September 01, 2009, 01:43:05 PM »
What year and spec ?
You'll need to ascertain just how rusty it is - which will probably be a sobering experience ! I'd suggest gutting the inside and leave just the dash in place. that'll allow you to see the floorpan, rear wings and rear struts clearly and make a list of what needs replacing. Do the same for the engine bay (should be easy to spot) and the outer panels. Sadly bubbling is almost always a symptom of more serious rust underneath and you're best to assume any areas of bubling need serious work.
Then see what bits are available (this site can help with the suplliers) The good news is that some panels are still available through specialists scatered around the world. Wings, bonnet come up fairly often on fleabay.
Mechanically there shouldn't be too many worries and just about everything is still available so I'd concentrate on the body for now even if the greasy bits are more fun.
Good choice BTW and welcome to the club.
icedmunkie
« Reply #2 on: September 01, 2009, 01:55:17 PM »
Its a 1984 HPE VX if that means much to you? I know its not got aircon but thats what windows are for!
Thanks for the advice, i know it had welding done previously but seems a good place to start as any!!
« Last Edit: September 01, 2009, 01:59:09 PM by icedmunkie » Logged
« Reply #3 on: September 01, 2009, 06:54:33 PM »
hmmm...why don't I ever get given a volumex?? worst areas to repair for rust are under the front screen corners, around the sunroof and the area in the rear wheelarch below the strut mounts especially where it meets the floor. Research the volumex  engine well,particularly the supercharger, before you attempt anything. There was a decent vx bonnet (with the extra bulge for the carb) on ebay recently and they are difficult to find so if you are serious snap it up quick if it is still on there seller ID was 'davikiman' he's a real Lancia fanatic . Your experience with British metal is, on the whole, best forgotten  Italian logic is totally different if you apply old tricks to your first Italian car it'll end in confusion, I find it difficult the other way around as, having run almost exclusively Lancias since 1983 except for maybe the last 4 years, I have a MG TF 135 as an everyday car the design thought process appears to have been quite different. In general the engineering in the Lancia is much better incidentally
« Last Edit: September 02, 2009, 08:11:34 AM by rossocorsa » Logged
« Reply #4 on: September 01, 2009, 07:12:16 PM »
Certainly does ! 3 litre performance from a 2.0. loads of lovely torque. One only 186 (allegedly) imported into the UK.
You might also consider a couple of books. Lancia Beta by Brian Long would be a good place to start - that's where the production figure came from. Amazon will have it if eBay don't. A haynes is available too though I don't think it covers the VX specifically.
Good call about the italian logic. For example there are two fuses for the lights front and rear is the way every other car does it. On the Beta it's front left + rear right and front right + rear left ! Sounds stupid but makes sense  - a fuse blows and you've still got some lights front and back
icedmunkie
« Reply #5 on: September 01, 2009, 09:35:49 PM »
I will look for that book sounds a good point to start from. I also got given with the car A Service manual which is quite thick, also a Smaller book that has loads of values and speacial tool numbers, wiring diagrams etc which is interesting plus another thin one from it. All from the lancia motor club libary. I have Haynes here too.
The rust on the front screen corners is that on the outside? I noticed a fair bit around the sunroof! Pulling out the interior out this Thursday!!
I will look up the bonnet this eve, thanks...
With regards to italian metal any tricks or stuff you recomend using? its all alien to me bodywork. I am used to heavy plates and plenty of underseal and bodywork is a big hammer and heat as brimabright doesn't rust thankfully!
thecolonel
« Reply #6 on: September 01, 2009, 11:56:09 PM »
Mmmmmmmmm.....  Volumex
sorry dreaming again, small point but LMC library books are normally lent rather than given.
make a great car that, and it'll take a nine foot christmas tree.
Geoff
« Reply #7 on: September 02, 2009, 12:01:01 AM »
Geoff
lmc library used to  produce photocopies of lancia publications for sale to members (or still do?? don't know as no longer a member can't stand the cobwebs any more) it's probably one of those from the days of Paul Mayo. reckon you could get longer than 9ft in .....using the sunroof as well Roll Eyes
« Reply #8 on: September 02, 2009, 08:17:15 AM »
just another thought you need to be careful when obtaining spare parts Italian logic is such that they often seemed to change some parts for no apparent reason sometimes when they look almost identical, factors part listings are almost always inaccurate and confusing as well particularly for the volumex, so if you are unsure ask on here first!!
icedmunkie
« Reply #9 on: September 02, 2009, 01:19:39 PM »
Geoff
These look to be all photocopies of manuals as some of the pictures are rather unclear but make for interesting reading nevertheless.
« Reply #10 on: September 03, 2009, 09:16:23 PM »
As it happens you can still buy the scanned versions of those (and the parts books) from the Viva Lancia website. The parts books are for earlier cars than yours but they're still pretty usefull.
blazer_one
« Reply #11 on: September 11, 2009, 07:10:56 AM »
hi
congrats on the volumex i am restoring a coupe version also in the gray and on a b plate.
in fact its went to the painters yesterday and i will get back in 6 weeks.
i'm sure you have checked but keep an eye on the oil feed to the supercharger and keep the level topped up cos if you run it dry it will be expensive.
i also have a 83  red coupe that i will be breaking once i have completed my gray one.
so if you want spares let us kmow. i would rather not strip it yet because it is outside but you are more then welcome to reserve parts including a bonnet i have which i am sure is in good condition.
i am based in carlisle i you want to visit.
again welcome to us small group of nutters who seem to be the only ones with good taste!!! Grin
Simon from Carlisle
1984 beta coupe vx and 1981 monte spyder
« Reply #12 on: September 12, 2009, 10:36:01 AM »
another grey one! mine is/was grey can't decide but I'm thinking that I might repaint a different colour when it's finished any suggestions??
« Reply #13 on: September 12, 2009, 11:10:29 PM »
I've always thought that the pale metallic blue suited Betas realy well.
« Reply #14 on: September 12, 2009, 11:58:32 PM »
had thought about blue as it matches the cloth interior well having said that our MG is light blue maybe two blue cars is too much.......I'll probably chicken out and go with grey again less to paint but i know if i do i might regret it
« Last Edit: September 23, 2009, 09:03:28 PM by rossocorsa » Logged
blazer_one
« Reply #15 on: September 23, 2009, 08:57:07 PM »
i think the gray is still the best colour passed a mazda 3 today in grey with black trim and smiled.
[img][/img]
hopefully this also shows a good pic of a gray vx
simon
Simon from Carlisle
« Reply #16 on: October 04, 2009, 10:59:51 AM »
That'd be your pic in the new Practical Classics then ?
TreviDash
« Reply #17 on: October 04, 2009, 09:16:12 PM »
What Huh?
Tell me Neil Campbell didn't just 'give' you that car for nowt?
I'd been in conversation with him about getting hold of it and he said many people had come forward offering good money
'84 Alfa 33 Gold Cloverleaf
'92 Daimler Six
icedmunkie
« Reply #18 on: October 05, 2009, 11:06:17 PM »
Yes that would be me.. and yes Neil did give me the car, I did have a helping hand as my best friend works alongside him on Land Rover Owner, suppose I got to do a good job now people know who I am.
Also alot of people offered him good money for the car for the supercharger rather than the car.
« Last Edit: October 05, 2009, 11:13:18 PM by icedmunkie » Logged
« Reply #19 on: October 06, 2009, 08:15:46 AM »
good job it's saved from the jaws of death of the MG nasties then Grin
Pages: [1] 2
