I would fit them dry or with dry PTFE spray because grease in this area will collect dirt and grit grinding the collars and springs away over time.
that is what I was thinking really, I checked the official workshop manual and it indicates (by omission of any instruction) dry assembly, I think this is correct in that the spring isn't intended to slip on the mounting. I just thinking really about protecting the rubber from perishing I might put a light coating of ptfe spray just on the edges after assembly.
