November 22, 2024, 04:05:38 AM *
Pages: 1 ... 7 8 [9] 10 11
Author Topic: Fuel Injected VX Beta Spyder  (Read 37016 times)
« Reply #160 on: January 10, 2022, 07:14:46 PM »
Hi Chris
I built the OE loom from a complete but very tatty VX Loom. Measuring and noting the wires by colour  I then ordered thin wall modern cable using the fact it caries more load for its size to fix OE design issues. Finding the colours  involved multiple suppliers, but only 2 substitutions.
I swapped Tape for cable ties at key junctions and made it one wire at a time end to end each loom sections on a large IKEA table. This was after Auto Sparks sent it back as too difficult for them!
I used modern sealed connectors in vulnerable spots in the engine bay and Red thin wall in place of black and white for the fuse box feeds. NB Junior Timer sealing boots replaced the rotted OE rubber boots.
The ECU and additional fuse box wiring is in a large Excel because there is no OE Wiring diagram. Drive By Wire, Sequential Injection, Cruise Control, Knock Control and on Board Wide Band Lambda took me beyond entry level ECU's
So much time is lost working out where to run the extra wires.
« Reply #161 on: January 10, 2022, 07:29:13 PM »
Hi Peter
I have not used bulk head connectors. Instead I have fuse box connectors to allow the whole system to be stripped out with some re-termination if ever needed. I used the redundant LHD pedal box holes with grommets from the NEC show (Ford I Think). If I was doing a bulkhead connector for the ECU I would use the Clutch one. NB I have a VX/IE Power Steering Firewall.
Things to watch out for when copying an OE Loom is that Thin wall cable is stiffer so harder to route and previous owners of the loom might have made it shorter to get clean connectors. Mixing Loom sections from different generations of cars is expert only head scratching stuff.
I still am not sure if the grey wire NS Boot feeds both IE Generation rear fog light for example. NB the fuse box has strange interconnect options on fog lights and an exterior relay wired into the mix.
« Reply #162 on: January 10, 2022, 07:54:58 PM »
Tremendous stuff, Eric. I understand that with the degree of non-standardness in your build that a custom loom was pretty much mandatory, but that doesn't lessen my admiration for the work you've done. I suspect you're blazing a trail here that many others will learn from and copy in the future. I know I will be referring back to these photos and build notes when I finally get round to doing something on a way more modest scale.
The cabin shot is particularly impressive/scary depending on which way you view it...
« Reply #163 on: January 11, 2022, 12:06:45 AM »
Hi Eric
Thanks for the reply and the comment re thin wall, surprised it is stiffer, did not realise that or is that due to upping the rating from OE?
So if I understand you, the wiring going through the bulkhead is on one or more removable connectors at the fuse box which is/are separate to the wiring in the engine that are on different connectors attached to the fuse box?
« Reply #164 on: January 11, 2022, 08:44:34 AM »
You are correct. I took time to group the new fuse box connections into cabin and engine bay before giving them Super seal connectors. I used spiral wrap because I could not know the wire lengths until they were run and it is not so obviously out of place in a classic as split convoluted tube. I am saving 1 bulkhead hole for the ECU to engine bay wires. I have deliberately brought the ECU to fusebox wires into the cabin where possible because warm and dry is better for wiring.
General principals are protect wire from movement, rubbing, heat water, ingress and fuse power supplies as close to source as possible.
PS plus tug test connections
« Reply #165 on: January 11, 2022, 10:47:34 AM »
Hi Eric
On reflection, I think trying to avoid the bulkhead connector would simplify and reduce later possible problems, provided I can easily unhook the cable in the engine bay, rather than the OE system on mine which is a complete abortion and almost impossible to do. At the end of the day I do not anticipate taking it out, but I would be a lot happier knowing I can do it without taking huge amounts apart to do it.
« Reply #166 on: January 11, 2022, 11:41:33 AM »
Hi Eric
Hi Peter,
From what I read, thin wall cable is stiffer because the sheathing is far more abrasion and cut resistant than the old sheathing and handles the rigours of automotive wiring far better. It's also supposed to be longer-lived, but I guess that will take time to prove.
« Reply #167 on: January 11, 2022, 11:43:45 AM »
Hi Graham
Ok, that makes sense. I will start ordering some and see just how flexible it proves. In general probably not an issue apart from under dash where things get pretty tight.
« Reply #168 on: January 11, 2022, 11:48:55 AM »
My (albeit limited) experience with it is that it doesn't take a 'set' in the same way the old stuff does. I think in use it's helpful to provide as many anchor points as possible, but I'm sure Eric can confirm or deny this. But the extra load capacity is very welcome. I beleive it came into being because OE manufacturers wanted the impossible - lighter weight cabling that had a higher load capacity. And they got it...
« Reply #169 on: January 11, 2022, 06:56:38 PM »
Hi Graham
I have a wide selection of large Stainless P Clips but still use the OE Cabin mounts for them. I kept OE engine bay loom under the structural beams on the sides just like the factory and used factory push in clips. The runs from DS to NS across the front use push on cable tie mounts because I have the radiator further forward to maximize room for things like the large K&N Air Filter box, Remote Oil Filter and Oil Stat.
« Reply #170 on: January 11, 2022, 10:02:43 PM »
Hi Eric,
I was surprised to see the inclusion of the original fuse box, especially
in its original location.
Knowing what it looks like inside, it doesn't look like an Eric thing.
Cheers, Nigel
« Reply #171 on: January 12, 2022, 09:00:40 AM »
Hi Nigel
Because I had a NOS Fuse Box and most are still working on cars after 40 years of abuse I went with it. They get damaged mostly by external loom faults and I will be fitting a heat shield to stop the exhaust baking the wires hard. If I wanted more torture I could re-wire the internals with thin wall, but not on my list!
« Reply #172 on: January 13, 2022, 06:04:17 PM »
On the subject of cable ties and cable tie fittings, there is a supplier only a couple of miles away from me called 'Cable Ties Direct', and as their name would indicate, they have an extensive range of cable ties and fittings. Here's a link to their online catalogue:
https://cableties-direct.co.uk/catalogue/
« Reply #173 on: February 11, 2022, 05:31:00 PM »
Dashboards Aghh. After stripping 4 for parts the best I can achieve still has a cigarette burn. I had to strip blast and paint the vent metal work. In the end I have one that will have to do and 1 for trial fit/check the wiring fits etc. So many bits of broken plastic plenty of removing rivets to use the best bits. Fortunately my buckets of plated bits came in handy.
[/img]
« Reply #174 on: February 11, 2022, 05:33:15 PM »
The top of these dashboards seem to become brittle which meant my best contender had a split / fracture.
lanciamad
Marcus Robinson
« Reply #175 on: February 12, 2022, 06:20:12 PM »
Is the vent metal work removable from the dash without being too disruptive? Mine is a bit unsightly and needs repainting but I didn't want to rip the dash apart too much trying to get them out if not an easy fix
2001 - Honda Civic Type R EP3
« Reply #176 on: February 12, 2022, 06:44:41 PM »
with the vent plastic removed the metal is easily removed for paint strip sand blast and re-paint. However good quality plastic trim removal tools and patience is needed to re-fit them. I had to take the walk away for a cup of tea options twice.
« Reply #177 on: February 13, 2022, 01:29:48 PM »
Hi Marcus thinking about it probably best to build a second dashboard and swap over.
Today I finally stopped procrastinating and installed the ECU in the PS Footwell after a lot trying it with a sample (huge) shoe. Set back into the surrounding sound proofing Foam I think it will not feel or look like an ugly lump just under the carpet.
« Reply #178 on: February 16, 2022, 10:16:28 AM »
Just to show the wiring is getting tidier as I move towards installing the head lining seals screen targa and back roof.
« Reply #179 on: February 16, 2022, 01:39:11 PM »
That should be the most acoustically dead Spyder anywhere, Eric. All the better to hear your sound system with!
