November 25, 2024, 07:35:48 AM *
Author Topic: Windscreen Washers  (Read 2794 times)
« on: September 22, 2019, 12:21:09 PM »
Does anyone know how to remove the 'bridge' that the facelift washers sit on without removing the expansion tank or fuse box? They seem to be fixed with some sort of flexible mounting?
I'm trying to get out my late washer tank to check a blockage....
betaveloce
Belgium Belgium
« Reply #1 on: September 23, 2019, 10:15:58 AM »
There's a screw in the gutter under the rubber that you see on the right of your photo.
If that's undone, you can just pull the complete 'bridge' out (the bottom part is simply pushed in a small rubber if I recall correctly)  Wink
« Last Edit: September 23, 2019, 10:17:41 AM by betaveloce » Logged
Beta Coupé 1.8 '74
Beta Spider 1.6 '80
Beta HPE 2.0 i.e. '82
Delta Integrale 8V '88
Ypsilon 1.4 16V '09
« Reply #2 on: September 24, 2019, 07:21:38 AM »
Thanks for that. Obviously, the water tank stops you getting to the screw in these later models. I'm guessing you must have to shuffle it to one side, or can the tank be manoeuvred out without removing the bridge?
betaveloce
Belgium Belgium
« Reply #3 on: September 24, 2019, 09:56:23 AM »
I think I didn't explain well: you just have to pull away the large rubber you see on the photo and then you will see the screw  Wink
Beta Coupé 1.8 '74
Beta Spider 1.6 '80
Ypsilon 1.4 16V '09
« Reply #4 on: September 26, 2019, 08:59:07 AM »
The screw is in the gutter. Great, thanks.
