November 21, 2024, 03:09:46 PM *
Author Topic: Converting wheel bolts to studs/nuts  (Read 3743 times)
« on: July 30, 2018, 10:28:16 PM »
Has anyone considered converting the standard Beta arrangement of wheel attachment using bolts to stud and wheel nut? It would make for much easier wheel mounting, as the studs would provide a natural guide to centre/align the wheel. Are there drawbacks to this arrangement? I guess over time the studs might get the thread chewed by removal/refitting of wheels, but other than that are there any downsides? I see plenty of conversion kits available on eBay.
Online Online
« Reply #1 on: July 31, 2018, 12:35:41 PM »
There's no danger of damaging steel bolts with alloy wheels. I can't see a disadvantage. On the other hand the Beta wheels are pretty light so I've never had too much trouble. My 406 Coupe (many other cars too I expect) comes with a locating pin you screw into a bolt hole before mounting the wheel - you could fabricate one of those without trouble.
« Reply #2 on: July 31, 2018, 05:01:38 PM »
That's a neat idea. All you'd need would be a long M12 x 1.25 bolt with the head cut off and a slot machined into the end to take a screwdriver. Makes wheel changing a breeze. The reason I ask is that I've just taken a set of 15" Thema 16v Turbo wheels to be powder coated and I'm planning to use those on the Beta longer term. Just looking at options for the new wheels.
lanciamad
Marcus Robinson
« Reply #3 on: August 01, 2018, 03:52:03 PM »
Been working well for me, if you think beta wheels are a pain try 16v integrale wheels.... So much easier now, would just advise to spend your time looking at the quality you are buying, they're normally cheap for a reason...
IMG_0034 by Marcus Robinson, on Flickr
IMG_0033 by Marcus Robinson, on Flickr
IMG_0035 by Marcus Robinson, on Flickr
2001 - Honda Civic Type R EP3
« Reply #4 on: August 01, 2018, 08:37:19 PM »
Marcus,
That looks a far better long term solution. I'd be looking for 10.9 high tensile studs at a minimum. Did you use threadlock on the studs where it bolts into the hub? And can you recall the overall lengths of the studs?
Cheers,
lanciamad
Marcus Robinson
« Reply #5 on: August 01, 2018, 10:39:56 PM »
Marcus,
Cheers,
Graham,
Most studs are 10.9, there are some sellers that don't know or won't list the tensile, the one's to avoid, so go for a reputable seller if you want to go the same route.
I used the red thread locker by Loctite on the short part of the stud in the hub and controversial or not, copper grease on the part of the stud the nut would thread up to the wheel, nut tightened up with an impact gun and a torque wrench not had any problems with any loosening of studs or nuts over the last couple of years.
I bought an extra two nuts to use as the locking nuts for winding each stud in. I can't remember the length, but it will differ per car/wheel setup. The stud length will need to be the length of the original bolt (including head) plus depth of any spacers used. I have a wider front spacer than rear for example so different length studs to match. You can always buy a Chinese £1 jobby to check your happy with length of stud before forking out for a decent full set, I aimed at having the top of the nut flush with or just below the end of the stud when fully tight.
All the best, Marcus
