November 23, 2024, 02:57:38 AM *
Pages: 1 [2]
Author Topic: Assembling Betaboyz gear linkage parts  (Read 14935 times)
Ammy
« Reply #20 on: October 22, 2018, 09:11:55 AM »
I only adjusted the one under the battery tray.  As he original link near the bulkhead was "solid" I assumed that had to be left.  That's always also assuming that the replacement link was "set" to the original length. I may have been lucky setting that one.
Ammy
« Reply #21 on: October 22, 2018, 09:17:04 AM »
I should have added that I , too,  had difficulty with 5th and reverse and according to my "garage wall" notes I gave it two complete turns anti-clockwise.
mangocrazy
Graham Stewart
« Reply #22 on: October 22, 2018, 11:59:20 AM »
Thanks Ammy = as that adjuster is the easiest to get at, I'm happy to take your advice and try the one under the battery tray...  Grin
2002 VW Transporter T4
2017 KTM Duke 690R
2008 Aprilia SL1000 Falco
1992 Ducati 888 SP3
1988 Honda VFR750F
1980 Yamaha RD350LC
« Reply #23 on: October 22, 2018, 12:14:42 PM »
Adjusting the linkage under the battery tray transformed the gear change on my ie. I could only get 1st and 2nd with extreme difficulty. Lengthening the rod (2 turns) got these selecting perfectly with 5th serviceable, but not as dead easy as it was. So it seems like you need to shorten the rod, but not much I would have thought.
I did this while the car was on the LMC stand at Manchester CCS. Never has such an easy job made so much difference!
mangocrazy
Graham Stewart
« Reply #24 on: October 22, 2018, 01:15:08 PM »
Thanks Neil, will give that a try. on mine it's only 5th that I can't select. I can get reverse so probably take the adjustment in small steps.
Does adjusting the length of the Betaboyz linkage rod at the back of the engine have any bearing on this? I set it to as close to the length of the OE part as possible, but may have got it slightly out. Adjustability can be a mixed blessing...
2017 KTM Duke 690R
1992 Ducati 888 SP3
1988 Honda VFR750F
1980 Yamaha RD350LC
« Reply #25 on: October 22, 2018, 05:24:11 PM »
Sorry, don't know the impact of the rear adjustment. However, if you have a Haynes manual, for once, the description of how to adjust the linkage is spot on.
mangocrazy
Graham Stewart
« Reply #26 on: October 22, 2018, 05:52:53 PM »
I'm pleased to report that one clockwise turn (ish) on the linkage (shortening the effective length) seems to have restored my 4 speed and reverse gearbox to 5 speeds and reverse; at least statically selecting the gears. I haven't got time to take it for a road test, as I'm flying back from France tomorrow and I'm in shutdown/lockdown mode.
So thanks everybody - for once it was a simple job. Would that they were all like that...  Cool
2017 KTM Duke 690R
1992 Ducati 888 SP3
1988 Honda VFR750F
1980 Yamaha RD350LC
Pages: 1 [2]
