November 21, 2024, 07:58:26 PM *
Pages: 1 2 [3] 4
Author Topic: Spider refurbishment  (Read 20272 times)
betabuoy
« Reply #40 on: September 20, 2020, 10:29:27 PM »
Awesome work Stuart. These are really tricky and complex areas...impressive stuff!
1967 Morris Minor Traveller
1925 Austin 7 Chummy
« Reply #41 on: September 21, 2020, 08:38:46 AM »
Hi Stuart
Impressive work that brings back memories of doing the Montecarlo sills 14 years ago!
« Reply #42 on: September 21, 2020, 09:58:19 AM »
Hi Stuart
Marvellous stuff, keep it up!
mangocrazy
Graham Stewart
« Reply #43 on: September 21, 2020, 04:57:33 PM »
Fantastic work, Stuart. I'm blown away by the quality of your work.
Graham
2002 VW Transporter T4
2017 KTM Duke 690R
2008 Aprilia SL1000 Falco
1992 Ducati 888 SP3
1988 Honda VFR750F
1980 Yamaha RD350LC
fred2660
Belgium Belgium
« Reply #44 on: September 22, 2020, 01:28:50 PM »
Nice work man, better than any carshop
WestonTB
« Reply #45 on: October 03, 2020, 04:15:17 PM »
Absolutely brilliant work, if I ever pull my spider to pieces I am sure I will face the same issues... only minus your skill & patience!
Confirms the excellent engineering in the Spider shell, no wonder there is no scuttle shake!  Keep up the good work Smiley
Online Online
« Reply #46 on: March 14, 2021, 10:52:42 PM »
Winter always slows things down - sometimes I forget how much. I'm really going to have to push on to have this ready for Beta 50.
Anyway the last six months (!) have been the rear passenger side floorpan.
It looks OK but is wafer thin in places  - stick a torch underneath and you get starry night effect
So corners first - sections had to be made up
Much tacking
Middle bit
Welded and ground  - Happy with that!
Now the main floor - again part doner car part made up from scratch
Not too bad but look at the earlier ( like 2017..) work on the right, shabby
New piece made up now solid again
Online Online
« Reply #47 on: March 14, 2021, 11:00:32 PM »
Next I need to replace the U section edge of the floor.
To do that the end of the cross member has to come out.
Mainly OK Underneath
I butchered the old one getting it out. I've got another but I need to replicate this bit for the captive nut
Two sockets and a bolt later
Bingo
U channel cut out
For some reason this was a right pig to weld.
New Cross Member end tacked in place
Et Voila
Next step the sill under the B pillar  - all this perforation is a result of a poor replacement 3/4 panel many years ago. New slapped on top of old creating a rust trap that just ate the top of the sill away.Thankfully the B pillar itself is very good. Shame I'll need to cut it really!
« Reply #48 on: March 14, 2021, 11:49:29 PM »
Looking good, keep at it!
« Reply #49 on: March 15, 2021, 08:29:52 AM »
Doing the job properly. Well done!
The Spring frenzy is nearly here.
Online Online
« Reply #50 on: September 26, 2021, 11:44:09 PM »
Thanks as ever for all the encouragement, it helps a lot.
Another 6 months has gone by so I'm overdue an update!
I left you with a pic of a sorry looking sill end.
Time to bite the bullet and cut it out
The back end of the inner sill was sort of still there!
A new corner piece was needed to link arch, floorpan, and inner wing. Out with the hammer
And it came out OK
A couple of local patches to the inner sill and an end closing plate
But what to do with this mess?
I used one of Mark's pattern sills for repair sections and them beat the whatsit out of it to get the right profile (2mm thick - heavy going)
This bit had to be made from scratch
Oops
Back on with the repaired sill
Looks good.
A new flange for the bottom of the B pillar
And in that went too
Again - happy with the result
That's the nearside sill & floor and A & B pillars done and hopefully good for another 40 years. Onto the offside rear.
« Last Edit: September 27, 2021, 12:01:38 AM by HFStuart » Logged
« Reply #51 on: September 27, 2021, 07:32:58 AM »
Brilliant work Stuart and frankly better than some so called restoration businesses. It is the layers of steel sections that make these cars a much harder repair proposition than old Fords, but also far stronger when they are made of metal!
Keep at it.
« Reply #52 on: September 27, 2021, 09:04:37 AM »
Hi Stuart
Amazing stuff, probably seems a long road to the end, but will be worth it looking at the current work.
mangocrazy
Graham Stewart
« Reply #53 on: September 27, 2021, 07:32:09 PM »
I'm seriously impressed with the quality and accuracy of your work, Stuart. Those are seriously good skills on display there. I know that I wouldn't have a clue where to start if I was in your position.
2017 KTM Duke 690R
1992 Ducati 888 SP3
1988 Honda VFR750F
1980 Yamaha RD350LC
squiglyzigly
« Reply #54 on: September 28, 2021, 08:14:36 AM »
Artisan quality work. Super impressive and I am rather jealous of such skills.
Unfortunately my VX HPE will not be done to this standard. ‘A’ I don’t have those skills, ‘B’ I don’t have enough patience, ‘C’ I tell myself ‘you can’t see it once the carpet goes down’  Grin
But I do put plenty of work in making it structurally sound, often with extra re-inforcement sections.
Bravo to you sir
unclejam
Full Member
« Reply #55 on: September 28, 2021, 11:17:08 AM »
Looks great Stuart - there is no substitute for digging out all the rot and putting clean metal in!  Looking at your work makes me worry about the potential state of my sills / pillars / hidden crevices!  Undecided
1980 Lancia Beta Spyder 2000
Various Alfas
Ducati Monster 1200s
« Reply #56 on: September 28, 2021, 04:51:20 PM »
Buy a bore scope/ colour inspection camera if you dare. I did at the NEC show 2 years ago and looked inside all the box sections on my Monte. I was pleasantly surprised that the Dynatrol has kept it all in factory condition.
unclejam
Full Member
« Reply #57 on: September 29, 2021, 10:36:45 AM »
Sounds like a useful investment - I may just do that.  I own more than one "water soluble" Italian car!  Grin
Various Alfas
Online Online
« Reply #58 on: September 03, 2023, 09:35:30 PM »
Well now  - I've just started to type this and I get a warning to say 'not updated for 120 days'  !   Sadly for various family reasons (who'd be a teenager in the modern world) I've not been able to put any serious work into the car for 18 months however today was the day to get back in the saddle!
Not many pics but a god start  - I know how I'll fix this now.
So right hand A Pillar base  - doesn't look too bad apart from where someone had butchered the sill to fit coupe rather than spider wings:
Brave Pills and cut along the dotted line
To reveal this  - could have been worse TBH  - the nearside certainly wasn't this good!
Cut back to good metal and start putting back together  - this time with the seam joint that was removed by the guy that 'fixed' the A pillars last time
Progress at last!
Online Online
« Reply #59 on: July 15, 2024, 01:35:58 PM »
Per my last post progress last year was slow but thankfully most of the problems are in the past and the welder has been out again.
Centre sill section replaced and the bottom of the internal A Pillar remade and tacked in place
Then the seam where the A Pillar and wheelarch was reinstated
And the outer A pillar replaced
Lastly the front of the sill replaced and checked to ensure it clears the wing  - something I forgot to do on the other side...
Then the last part of the U Channels to be replaced.
Last but not least the seat mounts had to be put back in. This time without being smacked which a large hammer to get them to line up which is what Zagato had evidently done!
I've not bent this  - it's exactly as it came off
The floorpan was thinner than I was happy with in the centre so:
Reinforcement plate from underneath
Bracket back in place
And with that the floors, sills A & B Pillars  - the whole central tub in fact is done!
« Last Edit: July 15, 2024, 01:58:19 PM by HFStuart » Logged
Pages: 1 2 [3] 4
