November 21, 2024, 08:01:53 PM *
Pages: 1 [2] 3 4
Author Topic: Spider refurbishment  (Read 20273 times)
Online Online
« Reply #20 on: April 15, 2020, 07:34:58 PM »
One of the bonuses of lockdown is more time in the garage so I've made good progress with the shot to bits drivers footwell.
This is where I started
And this is the state of the metal I cut out.
The frame underneath is thankfully really solid
Complicated compound curve bit put back.
Not too bad
Side piece with various shapes and curves
Again, cleaned upOK
Fred Flintstone moment
MDF Former made from old floor
Innocent bit of metal after a serious attack from the hammer
Trimmed carefully to shape
Welded in and waiting for grinding
Online Online
« Reply #21 on: April 15, 2020, 07:41:33 PM »
I'm the first to admit the repairs aren't invisible but the point is they're done,but welded in and very solid too.
Given I'm working with a medium claw and a small cross pein hammer, ancient vice, workmate a few lumps of metal for forming round and an admittedly pretty good welder I bought recently I'm really pleased with them!
Onwards !
« Last Edit: April 16, 2020, 10:20:48 AM by HFStuart » Logged
betabuoy
« Reply #22 on: April 16, 2020, 07:11:24 AM »
Excellent repairs Stuart; and I particularly like the attention to detail on the fabricated floor section. Your welding looks great... keep the pictures coming please.
1967 Morris Minor Traveller
1925 Austin 7 Chummy
smithymc
« Reply #23 on: April 16, 2020, 09:35:53 AM »
You have every right to be pleased with the results Stuart. Look really good.
Mark
mangocrazy
Graham Stewart
« Reply #24 on: April 16, 2020, 10:21:48 AM »
Excellent work, Stuart. That's professional standard in my book. What make of welder are you using? I'm guessing it's a MIG set.
2002 VW Transporter T4
2017 KTM Duke 690R
2008 Aprilia SL1000 Falco
1992 Ducati 888 SP3
1988 Honda VFR750F
1980 Yamaha RD350LC
« Reply #25 on: April 16, 2020, 11:46:26 AM »
Hi Stuart
That is excellent welding and forming better than some bodyshop efforts frankly. What Welder are you using?
Fitting bits and fixing snags all over my Beta Spyder!
fred2660
Belgium Belgium
« Reply #26 on: April 16, 2020, 06:54:36 PM »
nice work
Online Online
« Reply #27 on: April 16, 2020, 09:47:20 PM »
An R Tech 180  - not a top drawer welder by any means but a decent inverter one with a very steady arc and good control which helps no end with the thin bits. Much better that the budget Sealey / Clarke stuff.
« Reply #28 on: April 18, 2020, 11:54:28 AM »
My Clarke Item is due for Replacement.
Online Online
« Reply #29 on: April 18, 2020, 10:46:57 PM »
Much appreciated.
I should have put a link when I replied to Eric https://www.r-techwelding.co.uk/mig-welder-r-tech-i-mig180/?utm_source=google_shopping&gclid=Cj0KCQjwyur0BRDcARIsAEt86IA5pDnJ_FBZ1I3TunrcH5C8bXgwUuLDnIUIZyoArVTPMj5511uh1CkaAv6FEALw_wcB
Speaking of professional though  - when I first got this car I had a mobile welder repair the front strut tops and A Pillar bases. Where the inner wheel arch and the two pressings that form the A pillar join there is a seam where all three panels are spot welded together. I'd not really noticed before but rather than unpick the spot welds he just cut the seam off and blobbed them all together. I have more repairs to do in that area and it's going to be a lot more difficult now.
The red circles show where it's gone through. The line of weld where the seam should be is pretty obvious.
From the inside
This is the view from under the A pillar on the passenger side. The reinforcing section that links the bulkhead and wheel arch to the floor-pan is in a pretty bad way (it's 1.6mm too - way thicker than most of the steel on the car) while the repairs to the A pillar have rotted in 5 years.The red line shows where the seam would be. The odd thing is other than 4 inches at either end, the inside of the sills look like they've just left the factory.
Somehow I need to take this area apart, repair the corner of the A pillar and the end of the inner sill section and then replace the reinforcing section. Some head scratching to be done.
« Last Edit: April 18, 2020, 10:49:30 PM by HFStuart » Logged
« Reply #30 on: April 22, 2020, 08:25:47 PM »
Hi Stuart
When Paul Baker did mine he took the outer sills off for access to the mid section sills. The outers were in great condition but the mid sills!
BTW which gas are you using with your welder i.e. an Argon mix of what proportion?
Online Online
« Reply #31 on: April 22, 2020, 10:05:50 PM »
Notionally 5% Co2, 95% Argon (actually 5% Co2 93% Agron 2% Oxygen)
I'm thinking I may have to do similar although the mid sections are fine apart from at either end so I may just take the ends off and hide the joins in the sill
Online Online
« Reply #32 on: May 14, 2020, 02:23:17 PM »
Sometimes it's the little things in life.
I don't need them for a year of so but I'd got hold of a brand new pair of correct type side repeaters. I'm unnecessarily pleased with them!
« Last Edit: May 14, 2020, 02:26:46 PM by HFStuart » Logged
« Reply #33 on: May 14, 2020, 02:32:01 PM »
Hi Stuart
That is a good find, particularly like the outer sheath on the wiring, all the ones I have did not have it or is degraded.
You should also be pleased with the floor panels. Well done
Online Online
« Reply #34 on: May 14, 2020, 02:55:26 PM »
Yep - the rubber has very sightly shrunk with age but I can work with that.
Speaking of floor panels (thanks...)
A few more hours in the garage
And another chunk of floor panel is in place. This one, I confess, mainly came from the HPE I cut up a few years ago
The bit that was rotten and mostly not there was the front bit with the big drain hole ( I know there's a smaller one supposed to be there) so I only needed to fabricate that part. Sods law it's the most complex bit but again I'm happy with the result
I thought about not having the hole but it's original and I have the metal bungs to plug it with so why not. I'll add it to the other side later
Next step fully weld this in and then start on the A pillars.
« Last Edit: May 14, 2020, 02:58:18 PM by HFStuart » Logged
« Reply #35 on: May 15, 2020, 07:42:48 AM »
Are the holes emergency drainage?
Online Online
« Reply #36 on: May 15, 2020, 11:49:54 AM »
I really don't know. I'd guess they were for paint drainage when then were primered as they're at the low points (in the back floor pans too) but they could equally be locating points for the production line.
And why have one big and one small on each side.
Online Online
« Reply #37 on: September 20, 2020, 09:01:59 PM »
Update  - work from May - August. You might need to get a drink.
Possibly you recall the bottom of the A Pillar looked like this
It was time to start cutting
And underneath it wasn't pretty
Cutting back to good metal left me with this
Sill centre section tacked in place
To give a reference line to make this - part old HPE floor  - part new fabrication
Which was a pleasingly good fit
« Last Edit: September 20, 2020, 09:11:44 PM by HFStuart » Logged
Online Online
« Reply #38 on: September 20, 2020, 09:07:21 PM »
And welded up well
There's an internal panel that transfers load to the sill  - that needed to be remade and fitted
Then to put the sill back together
Will all that done time to start on the corner  - a pretty complex shape so I roughly formed the edge first
Then teased a panel into shape to fit it.
Fully welded it looked OK
And fitted well too
Just this fillet to put in
Online Online
« Reply #39 on: September 20, 2020, 09:10:38 PM »
Onto the inner wing - this is where it had been bodged and the flanged joint removed. So that got cut out and put back in layers - three pieces join at this flange
Flange now back in place!
Outer panel back on too
That's one corner properly sorted!
Pages: 1 [2] 3 4
