November 22, 2024, 02:17:12 PM *
Pages: [1] 2 3 4
Author Topic: 1978 coupe  (Read 26848 times)
0 Members and 18 Guests are viewing this topic.
skidmarc
« on: August 31, 2017, 08:01:35 PM »
started bare metal restoration
skidmarc
« Reply #1 on: August 31, 2017, 08:02:58 PM »
more pics
skidmarc
« Reply #2 on: August 31, 2017, 08:09:20 PM »
more
skidmarc
« Reply #3 on: August 31, 2017, 08:10:27 PM »
more
skidmarc
« Reply #4 on: August 31, 2017, 08:12:10 PM »
more
skidmarc
« Reply #5 on: August 31, 2017, 08:13:40 PM »
more
skidmarc
« Reply #6 on: September 06, 2017, 07:35:08 PM »
went to remove windscreen and surround took 1 hour to remove surround trim did'nt even damage trim god 39 year old mastic is like concrete
then i spent another hour carefully going around the windscreen cutting mastic with a multi tool then when i was about to lift the screen i noticed an old stress crack
dam dam dam and dam i know it was'nt me as the crack was dark in colour and was hidden by the trim. as soon as i lifted screen 1cm crack top to bottom
skidmarc
« Reply #7 on: September 06, 2017, 07:37:07 PM »
so i had a smashing time getting screen out
skidmarc
« Reply #8 on: September 06, 2017, 07:48:12 PM »
then i went on to remove dash board to find a really poor scuttle panal any ideas where to get one
skidmarc
« Reply #9 on: September 06, 2017, 07:56:08 PM »
removed carpet
skidmarc
« Reply #10 on: September 06, 2017, 07:58:11 PM »
its not rust you can see its the fibres from the old sound proof
skidmarc
« Reply #11 on: September 06, 2017, 08:01:37 PM »
went back to the rear wind drain channel which was rusty so i gave it some phos acid to drink left it on for 30 mins
« Reply #12 on: September 06, 2017, 09:18:35 PM »
How did you go about getting the screen trim out without damaging it? This is a job I have to do in the next couple of weeks.
« Reply #13 on: September 07, 2017, 06:48:18 AM »
Betaboyz do a replacement scuttle panel, but it is a made to order part and takes some time to come. Best order early if you want one.
I suspect nearly every Beta that has never had the screen out is similar under the mastic....
« Reply #14 on: September 07, 2017, 07:36:40 AM »
Hi Neil
Oddly enough mine was not (original hot wire sealant still installed), but plenty of other areas where it was bad.....!
skidmarc
« Reply #15 on: September 07, 2017, 09:33:45 AM »
I used a multi tool on setting one and placed it between trim and glass and just slowly moved it side to side and in and out .
I've looked on beta boys but can't see the panel I'll email mark
fred2660
Belgium Belgium
« Reply #16 on: September 07, 2017, 06:13:47 PM »
nice pics. not so much rust until now.
how is the trim around the windows attached? is with mastic or with clips?
thanks
« Reply #17 on: September 07, 2017, 07:38:29 PM »
The original method is to use something like cheese wire with a handle attached on both ends the wire being fed through then saw out the glass one person on inside one on outside
skidmarc
« Reply #18 on: September 07, 2017, 10:37:59 PM »
the trim is attached with mastic ill take a picture of back of trim to show where the the mastic is . the cheese wire method is old school.most window repair people use a multi tool which vibrates  side to side and has different size bits its fantastic to use.iam glad i have found some rust in my coupe because i didn't feel like a beta owner.but i wish the bugger was some where else but never mind.
skidmarc
« Reply #19 on: September 07, 2017, 10:43:20 PM »
i noticed when taken my screen out if you look inside the car at the windscreen rubber you can bend the rubber away from the car and hopefully lift screen and glass in one but i may be wrong
Pages: [1] 2 3 4
