November 24, 2024, 02:14:49 AM *
Author Topic: Headrest removal  (Read 3641 times)
AndM
Newbie
2000ie Coupe 1984
« on: August 15, 2017, 06:06:35 PM »
Hi, can anyone tell me how to fully remove the front seat headrests. When pulled up to their full extent there seems to be a stop that prevents them from beng fully removed from the seat.
betaveloce
Belgium Belgium
« Reply #1 on: August 16, 2017, 10:27:35 AM »
You have to take the back of the seat off and then you will see two clips that you have to remove  Wink
Beta Coupé 1.8 '74
Beta Spider 1.6 '80
Beta HPE 2.0 i.e. '82
Delta Integrale 8V '88
Ypsilon 1.4 16V '09
AndM
Newbie
2000ie Coupe 1984
« Reply #2 on: August 30, 2017, 08:28:24 PM »
Many thanks for that. I took a look and the back seems to be held in place by 2x small screws at the bottom but access to these is blocked by a tube running side to side at the base of the seat back. Can't see how that is easily removed. Would be great if you had experience of how to approach this. Many thanks.
betaveloce
Belgium Belgium
« Reply #3 on: August 31, 2017, 10:56:00 AM »
Yes, it does take some fiddling, but with a small screw driver or some pliers you should be able to remove the screws (normally they are not that tightly screwed).
There should also be two screws at the top (visible after pulling the headrests up).
Good luck  Wink
Beta Coupé 1.8 '74
Beta Spider 1.6 '80
Ypsilon 1.4 16V '09
