November 23, 2024, 05:50:44 AM *
Author Topic: Rotor Compatibility  (Read 5179 times)
SIMid
Australia Australia
« on: June 20, 2017, 11:27:16 PM »
Hi everyone,
My mechanic who had put my spider through "the pits" is not sure if the current rotors will pass. He was checking rotor depths and said if not, I will need to get a set.
Question I have is that, will rotors from a Coupe or HPE fit the Spider? I have been told that they are all compatible (fronts are the same and rears are the same for all), except for the Monte.
Just thought I'll ask as I may come across a set of discs.
Thanks!
Simon
13 Golf GTi - 81 DMC12 - 79 Lancia Beta Spyder
« Reply #1 on: June 21, 2017, 05:32:50 AM »
All Beta front rotors are the same, so Coupe/HPE will fit as well
SIMid
Australia Australia
« Reply #2 on: June 21, 2017, 07:44:47 AM »
Hi Peter, the same deal with the rears? All rear rotors are compatible across the Coupe/HPE/Spider?
Simon
« Reply #3 on: June 21, 2017, 08:08:59 AM »
Yep.
« Reply #4 on: June 21, 2017, 11:00:04 AM »
As Stuart says, all the same, so no chance of getting mixed up, the fronts are different to the backs, though appear similar.
There was a member on the Lancisti site who had problems sourcing the rears in the US, but they appear available in Europe, hopefully not a great problem sourcing either for you in Oz?
Also curious if they are called rotors or discs over there?
« Last Edit: June 21, 2017, 11:02:04 AM by peteracs » Logged
SIMid
Australia Australia
« Reply #5 on: June 22, 2017, 12:00:45 AM »
I call them discs, but I grew up in the British system. But when I call up asking for parts, they seem to call them rotors.
Thanks for the replies everyone!
Simon
fred2660
Belgium Belgium
« Reply #6 on: July 13, 2017, 08:10:11 PM »
do EBC d067 and d068 brake discs fit a coupe 1600?   some sites say they fit others dont
http://www.ebay.ie/itm/EBC-PREMIUM-OE-FRONT-DISCS-D067-FOR-LANCIA-BETA-COUPE-2-1976-85-/111528618592?hash=item19f79faa60:g:se4AAOSw7ThUc~-P
thanks
« Reply #7 on: July 13, 2017, 08:22:46 PM »
As all Betas except the Monte have the same brakes and this ref gives the two p/n, then yes they are the correct parts
https://ebcbrakesdirect.com/automotive/lancia/beta/1.4-1973-1976/6247
DeXiTroN
Australia Australia
« Reply #8 on: October 14, 2019, 10:06:38 AM »
I have a set in Australia.. Good nick - PM ME.
BTW- I have loads of parts too!
George-S
« Reply #9 on: October 14, 2019, 08:36:42 PM »
Just to say I have contacted lots of these ebay companies with Coupe brakes for sale most don't actually have stock.. but you can give them a shout Sad
I have also emailed about 6 or 7 manufacturers who use to produce discs but unforantley none are willing to put them back into production.
I have tracked down a few but it does come at a cost...
https://www.bielstein.com/Brake-disc-rear-axle-set-2-pieces-Lancia-Beta
http://autoricambifirat.it/shop/index.php?main_page=product_info&cPath=5_509_516&products_id=12463
https://www.amazon.it/Brembo-08-2597-10-Disco-Anteriore-dischi/dp/B005O97GNG/ref=au_as_r?_encoding=UTF8&n=1571280031&newVehicle=1&s=automotive&selectVehicleSource=vehicle%20attributes&submodelId=7581
Cheers George
