November 26, 2024, 02:38:16 AM *
Author Topic: Engine not turning over fully  (Read 3090 times)
Spyderfan
« on: May 13, 2017, 06:05:27 PM »
Hi guys was after some advice please ...
Engine has not been started 3 years at least , I've pulled plugs and put oil in bores .
Can turn over 3/4 way round then stuck
Could this be valves ? Next step?
gengis
« Reply #1 on: May 13, 2017, 10:05:16 PM »
sounds like a stuck valve, confirm by taking the cam covers off and you should see the offending valve bucket still compressed while the cam lobe is clear.  I assume that the cam belt is driving the cams?.
1983 - Lancia Beta Coupe
1982 - Fiat 124 Spider
2012 - Alfa Romeo Mito
2011 - Fiat Fiorino
2006 - BMW F800st
« Reply #2 on: May 14, 2017, 08:06:22 AM »
Or Bore Corrosion. If you can get hold of an endoscope/ bore inspection gadget have a look down each of the bores. It is not worth forcing the issue that will only lead to expensive damage. Also confirm the Aux DS is not miss timed and locking against number 2 conrod.
Good luck, but expect head removal in the not very distant future.
« Reply #3 on: May 14, 2017, 09:43:43 AM »
You changed the cam belt on that a few weeks ago didn't you?
I'd put money on the auxiliary driveshaft being miss timed and the lobe hitting the crank. If it's a hard stop rather than a gradual tightening then its even more likely. As mentioned below a stuck valve is easy to identify and eliminate.
Spyderfan
« Reply #4 on: May 14, 2017, 10:13:00 PM »
Thanks for all your replies guys ... Very helpful  Smiley
