fred2660
« Reply #40 on: August 26, 2017, 03:18:32 PM » |
I am working on the front suspension. I dismantled the front wishbones and ordered new bushes. In the haynes manual there is a difficult explanation how to remove and replace them, needing special tools. Off course I dont have those tools, and i dont think my replacement bushes are originals. They seem to be Poly. My plan was to use the spacers from the old bushes and reuse that and just press the new bushes in. Has somebody any experience with this . comments are highly appreciated. Thanks I also bought new rear ARB bushes (photos later) IMG_3034 by frederikleyers, on Flickr IMG_3035 by frederikleyers, on Flickr IMG_3036 by frederikleyers, on Flickr IMG_3037 by frederikleyers, on Flickr IMG_3038 by frederikleyers, on Flickr IMG_3039 by frederikleyers, on Flickr IMG_3040 by frederikleyers, on Flickr
« Last Edit: August 26, 2017, 09:44:05 PM by fred2660 »
« Reply #41 on: August 27, 2017, 10:51:44 PM » |
For the front bushes, a press or long bolt etc will do to get the new bushes in. I used Poly ones and I put the bushes in first by hand and then pressed the central spindles in after, cannot remember if I needed to use a bolt to do it or not, guess it depends how difficult the bushes prove to be.
fred2660
« Reply #42 on: September 27, 2017, 07:01:44 PM » |
a little update after a lot off work. reinstalled back suspension making new brake pipes painted tha interior took the engine out ... IMG_3042 by frederikleyers, on Flickr IMG_3043 by frederikleyers, on Flickr IMG_3066 by frederikleyers, on Flickr IMG_3067 by frederikleyers, on Flickr IMG_3068 by frederikleyers, on Flickr IMG_3069 by frederikleyers, on Flickr IMG_3070 by frederikleyers, on Flickr IMG_3071 by frederikleyers, on Flickr IMG_3127 by frederikleyers, on Flickr IMG_3129 by frederikleyers, on Flickr IMG_3130 by frederikleyers, on Flickr IMG_3132 by frederikleyers, on Flickr IMG_3133 by frederikleyers, on Flickr IMG_3134 by frederikleyers, on Flickr IMG_3137 by frederikleyers, on Flickr IMG_3138 by frederikleyers, on Flickr IMG_3139 by frederikleyers, on Flickr IMG_3140 by frederikleyers, on Flickr IMG_3141 by frederikleyers, on Flickr IMG_3143 by frederikleyers, on Flickr IMG_3144 by frederikleyers, on Flickr IMG_3145 by frederikleyers, on Flickr IMG_3146 by frederikleyers, on Flickr IMG_3147 by frederikleyers, on Flickr disassembling the brake booster was hell. I couldn't reach the top bolts so I had to disassemble the pedals also (which wasnt the plan). In the haynes manual its easy explained how to take the pedals out, but reality was something else. I fear the day I have to reinstall them the engine bay is quite dirty but the metal is good. like i said earlier I installed new rear suspension struts. after installing the whole thing and putting the tires back on, it seems to me that the car is sitting high (?) like you can see on the photos. next job is cleaning and painting the engine bay, cleaning the subframe and installing the front suspension again. than I wil start with filler. greets
fred2660
« Reply #43 on: September 29, 2017, 08:11:21 PM » |
remember I said the metal was good.... aaaahh wishfull thinking the lower front off the engine bay is a bit rusted. Because the subframe is bolted here to the frame , and I don't want to weld upside down no more, I've cut the whole profile out, so I can repair it in a comfortable , propper way. IMG_3151 by frederikleyers, on Flickr IMG_3152 by frederikleyers, on Flickr IMG_3153 by frederikleyers, on Flickr IMG_3154 by frederikleyers, on Flickr IMG_3155 by frederikleyers, on Flickr IMG_3149 by frederikleyers, on Flickr
RichB
« Reply #44 on: September 30, 2017, 01:32:27 PM » |
This guy deserves a medal! Keep it up Fred!
cheeky monkey
« Reply #45 on: September 30, 2017, 05:38:21 PM » |
Such well documented hard work. Please keep sharing the progress
1979 beta coupe 1300
betaveloce
« Reply #46 on: October 02, 2017, 12:29:29 PM » |
It looks like this is going to be one the best sorted Betas in Belgium when it's finished Keep up the good work!
Beta Coupé 1.8 '74 Beta Spider 1.6 '80 Beta HPE 2.0 i.e. '82 Delta Integrale 8V '88 Ypsilon 1.4 16V '09
smithymc
« Reply #47 on: October 03, 2017, 07:40:56 AM » |
Inspirational work all round.
Keep it up.
betaveloce
« Reply #48 on: October 03, 2017, 08:38:24 AM » |
fred2660
« Reply #49 on: October 07, 2017, 07:42:22 PM » |
thanks boys for the coments @betaveloce: If i had the space... I repared the front profile. there was quite a lot of rust and i had to replace a lot of metal. I decided not to cut(?) the welds away. the welding is going better and better IMG_3156 by frederikleyers, on Flickr IMG_3157 by frederikleyers, on Flickr IMG_3158 by frederikleyers, on Flickr IMG_3159 by frederikleyers, on Flickr IMG_3160 by frederikleyers, on Flickr IMG_3161 by frederikleyers, on Flickr IMG_3162 by frederikleyers, on Flickr IMG_3163 by frederikleyers, on Flickr IMG_3165 by frederikleyers, on Flickr IMG_3166 by frederikleyers, on Flickr IMG_3167 by frederikleyers, on Flickr IMG_3168 by frederikleyers, on Flickr IMG_3169 by frederikleyers, on Flickr IMG_3170 by frederikleyers, on Flickr IMG_3171 by frederikleyers, on Flickr IMG_3206 by frederikleyers, on Flickr IMG_3207 by frederikleyers, on Flickr IMG_3209 by frederikleyers, on Flickr IMG_3212 by frederikleyers, on Flickr IMG_3213 by frederikleyers, on Flickr IMG_3214 by frederikleyers, on Flickr IMG_3217 by frederikleyers, on Flickr I seperated the subframe from the engine. very dirty and a bit of rust. The rust is on both sides of the frame on the same place. There is also a piece that is pressed in, probably from jacking up the car. IMG_3221 by frederikleyers, on Flickr IMG_3222 by frederikleyers, on Flickr IMG_3223 by frederikleyers, on Flickr IMG_3224 by frederikleyers, on Flickr IMG_3225 by frederikleyers, on Flickr IMG_3226 by frederikleyers, on Flickr IMG_3236 by frederikleyers, on Flickr IMG_3238 by frederikleyers, on Flickr IMG_3239 by frederikleyers, on Flickr pressed in, so i cutted out IMG_3242 by frederikleyers, on Flickr IMG_3244 by frederikleyers, on Flickr IMG_3245 by frederikleyers, on Flickr greats, fred
fred2660
« Reply #50 on: October 13, 2017, 04:50:50 PM » |
some new parts arrived. had to wait a long time for them. But if you look some on the internet you can do some good deals IMG_3262 by frederikleyers, on Flickr IMG_3264 by frederikleyers, on Flickr IMG_3265 by frederikleyers, on Flickr IMG_3266 by frederikleyers, on Flickr IMG_3267 by frederikleyers, on Flickr IMG_3269 by frederikleyers, on Flickr realy happy with the gaskets, some parts drying and waiting to be installed. IMG_3270 by frederikleyers, on Flickr IMG_3271 by frederikleyers, on Flickr IMG_3272 by frederikleyers, on Flickr IMG_3273 by frederikleyers, on Flickr IMG_3274 by frederikleyers, on Flickr IMG_3275 by frederikleyers, on Flickr the subframe is out to be sanded and powdercoated. I was realy fed up with the grinding greats
« Reply #52 on: October 22, 2017, 08:11:39 PM » |
Nice work, I enjoyed rebuilding the master cylinder, less so the front wheel cylinders with the really difficult retaining ring.....
On the lower ball joints for the front wishbones, I found one of the new ones I bought, different suppliers for both bought at different times, had too high a threaded section and had to cut it down, otherwise it fouled the drive shaft assembly. I think it was a Delphi one from memory.
« Last Edit: October 22, 2017, 08:14:47 PM by peteracs »
fred2660
« Reply #53 on: October 24, 2017, 06:14:57 PM » |
@ peter: you are right. the new balljoint is probably gonna get too high IMG_3298 by frederikleyers, on Flickr meanwhile I have put the engine on an enginestand IMG_3312 by frederikleyers, on Flickr gonna work a bit on cleaning the thing. its so dirty (promise to myself: next time i do a restoration, i have to have some kind of sandblaster) During the work on the car I sometimes encounter 'yellow marks'. Is this a factory thing or something a previous owner has done? IMG_3317 by frederikleyers, on Flickr greats
« Reply #54 on: October 25, 2017, 04:40:57 PM » |
It looks like that ball joint I designed to mount under the wishbone rather than on top of it.
« Reply #55 on: October 25, 2017, 05:31:13 PM » |
Hi Stuart
The issue is not that. If you mount top or bottom, the thread length and taper still mean the thread butts up against the CV joint when fully tightened.
« Reply #56 on: October 25, 2017, 05:33:45 PM » |
Ah, gotcha!
fred2660
« Reply #57 on: October 28, 2017, 04:55:04 PM » |
Got the subframe back so I could weld the front profile back in IMG_3335 by frederikleyers, on Flickr IMG_3336 by frederikleyers, on Flickr IMG_3337 by frederikleyers, on Flickr IMG_3338 by frederikleyers, on Flickr IMG_3346 by frederikleyers, on Flickr IMG_3347 by frederikleyers, on Flickr IMG_3349 by frederikleyers, on Flickr IMG_3350 by frederikleyers, on Flickr IMG_3351 by frederikleyers, on Flickr IMG_3352 by frederikleyers, on Flickr meanwhile I cleaned the oilpump IMG_3327 by frederikleyers, on Flickr IMG_3324 by frederikleyers, on Flickr IMG_3323 by frederikleyers, on Flickr IMG_3322 by frederikleyers, on Flickr question: I have never rebuild an engine before. Is it difficult to replace the head gasket? cya
« Reply #58 on: October 28, 2017, 05:08:21 PM » |
Check the oil pump clearances while it's apart.
Head gaskets are pretty simple with the engine out. You might want to think about new head bolts.
« Reply #59 on: October 29, 2017, 12:27:15 PM » |
As regards head gasket you may want to consider changing to stretch type bolts, very late betas used this type, I think many later lancias use the same bolt spec, you would need some ribe tools to tighten them. Also consider modifying the top metal coolant pipe to late spec as on VX, helps with pressure in cylinder head reduces risk of HGF from memory it's just a couple of very short extra pipes to add on
« Last Edit: October 29, 2017, 12:28:46 PM by rossocorsa »
