November 21, 2024, 12:54:10 PM *
Pages: 1 ... 7 8 [9]
Author Topic: beta coupe 1979 - 1600 from belgium  (Read 73164 times)
fred2660
Belgium Belgium
« Reply #160 on: September 05, 2020, 01:00:26 PM »
Quite sure i had the original bonded glass. But i have fitted the seal without the window and it fits fine. Ans the window fits in the seal. Why wouldnt it work then?
Don't like the the rubber overlap though
fred2660
Belgium Belgium
« Reply #161 on: September 28, 2021, 04:39:23 PM »
4 and a half years ago, in an impulsive moment, I bought my coupé.  I was not familuar with the beta, or lancia, and was just looking for a Quick project.
Today it passed local MOT.
Its not yet finished, but can finaly take it for a spin.
Thanks for all the advice and help on this forum
What did i do? A lot of welding (way more than anticipated) new subframe, new bushings around, new shocks, Total new brake system, partially rebuild engine, new oilpump, new filters, new sparkplugs, new gearbox, rebuild carb, new grill, paintjob, ...
Still to do: new exhaust, uphulstery, finetuning carb
« Reply #162 on: September 28, 2021, 04:59:17 PM »
Well done. Great to see hard work with a great result.
« Reply #163 on: September 28, 2021, 07:05:59 PM »
Hi Fred
Great work, you are obviously committed! I can sympathise with the time taken.
Sandro
Denmark Denmark
« Reply #164 on: September 30, 2021, 09:04:03 AM »
Congradulations Fred,
Quite a different car, quite a knowledgeable owner!
Well done.
A.
1972 Honda cub
1984 Silver 2000i HPE
2005 Opel Vectra ( everyday )
fred2660
Belgium Belgium
« Reply #165 on: August 04, 2022, 07:56:07 PM »
Hi. I have an issue with the nut that secures the wheelhub and is screwed on the outer cv joint shaft.
In the manual it says 314 nm of torque. If i torque it that hard my wheel is stuck. I cant turn it anymore.
Any thougts?
squiglyzigly
« Reply #166 on: August 04, 2022, 08:18:14 PM »
Have you changed the cv joint?
Regards
Ian
fred2660
Belgium Belgium
« Reply #167 on: August 04, 2022, 08:26:06 PM »
Yes
« Reply #168 on: August 04, 2022, 08:37:20 PM »
This is a known problem (by me and a few others at least). Some of the Cv joints which are sold for the Beta bind on the hub. Compare the flange with an old one and you will see they are different. I recently bought two and they need to be machined to fit.
So you can either return it or get it machined which should be a simple job.
The original CV had a dust cover which fits onto the joint next to the flange which goes against the bearing.
fred2660
Belgium Belgium
« Reply #169 on: August 04, 2022, 09:05:45 PM »
Thanks, will check it
fred2660
Belgium Belgium
« Reply #170 on: August 05, 2022, 04:36:53 PM »
That was indeed the problem.
 Thanks peter. You warned me for this when i initially installed the new  cv joints, but i didnt understood what you ment. In other cars these nuts are typicly fingertight .
