November 24, 2024, 11:40:34 AM *
Author Topic: Heater unit replacement - does it need gasket to bulkhead?  (Read 3686 times)
« on: March 21, 2017, 10:11:19 AM »
Hi All
Given it is a few years since I removed the heater unit from the bulkhead and now ready to reinstall, I need to understand if there is a gasket between the unit and the bullhead?
The parts book is unclear as no specific one is shown in the explosion picture and cannot see one in the list. Also I have two units and neither appear to have had one or at least there are no remains to be seen, but if I look at the bulkhead there is what I think are the remnants of a cork like gasket?
Given the position of the heater unit, it appears to be a natural water trap or is there a rubber seal which goes around the top of the opening in the bulkhead?
Online Online
« Reply #1 on: March 21, 2017, 12:39:11 PM »
Hi Peter
I cannot remember for the Beta heater but on a Monte there is a foam gasket which I remade in closed cell foam to reduce leaks and remove a built in water trap.
squiglyzigly
« Reply #2 on: June 03, 2017, 05:10:40 PM »
I can't remember if there is a gasket to the bulk head but if my memory serves me, there is a rubber drain boot/pipe that drops any moisture back into the engine bay. So there probably isn't any need for a gasket.
There is a foam seal for the air flap but I think that is only to close the air flow, and not to prevent ingress of water as that is always going to happen on a rainy day with the fan on and flap open. Hence the drain pipe.
« Reply #3 on: June 03, 2017, 06:01:07 PM »
Thanks for the replies. The drain points on the area where the wiper motor sits etc will take the bulk of the ingress from the vents, however I was thinking of the small gap around the heater where it protrudes up into that area, albeit small/thin it looks to me like a built in water trap or easy access for water into the main cabin depending how sealed it is around the heater. I think I may use some rubber or foam to just make sure. On the flap you are correct there is foam which I have replaced, but that is mainly there to stop the flap rattling against the main body when closed I suspect and will having only a little bearing on water ingress into the heater given its inverted position.
