November 27, 2024, 04:55:49 PM *
Author Topic: Sump (and other gaskets) to use sealant as well?  (Read 2900 times)
« on: November 18, 2016, 08:24:43 AM »
Hi All
Just replacing my sump gasket and wondered if it is necessary to also use any sealant on it to get a guaranteed seal or just use the gasket?
The old one appears to be unsealed and from what I can tell did not leak.
lukasdeopalenica
Australia Australia
« Reply #1 on: November 18, 2016, 08:38:57 AM »
I have always used just a cork gasket and it works well but sometimes sump bolts needed retightening as the gasket sat a bit with time.
Subaru Outback 3.0R
jreacock
England England
« Reply #2 on: November 18, 2016, 09:55:56 AM »
The advice from Guy Croft, is to use a small amount of sealant around the corners (the seal housing interface).
I have just rebuilt my engine, (using the cork gasket) and used a bit of blue hylomar blue sealant around the joins, and also smeared a bit of grease on the engine side of the gasket - as it recommends in the Haynes manual. I think that the main reason for doing the latter, is so that it's easier to remove in the future.
69 Fulvia 1.6HF S1
71 Works Fulvia 1.6HF
75 Gp4 Stratos HF
81 Beta Spyder 2.0
82 037 Rally stradale
« Reply #3 on: November 18, 2016, 11:00:29 AM »
Make sure the sump face is flat though - if the sump bolts have been over tightened or fitted without washers at some point the flange will have bent around the bolts leading to leaks between them. I've always used a smear of red hermatite (or similar) and have not had any problems
« Reply #4 on: November 18, 2016, 10:02:15 PM »
Hi All
Thanks, I will use some of the gasket sealant and see how we get on.
