November 21, 2024, 12:57:05 PM *
Author Topic: Failed Steering Rack Bush?  (Read 4542 times)
capriblu
« on: September 11, 2016, 02:27:18 PM »
Hi All,
Had the steering rack bush replaced on my coupe (manual TRW rack) about 4 years ago with a repro item.  Have just noticed after a long run today the same knocking noise through wheel.  Can seem to move rack up/down slightly when grabbing n/s control arm; some movement but less pronounced when doing similar with O/S control arm -   Am I on the right lines?
If it is the bush then is failure after just a few years and probably not much more than 7/8 K miles normal?
See that Betaboyz parts now shows a Polyurethane item as alternative?  Has anybody any experience of this as an alternative?
Finally, last time had local mechanic/garage that I know change bush as didn't fancy trying to do this job at home without access to lift.  Is this straightforward if I get car up on axle stands or is it not worth the faff?
All advice greatly appreciated.
Thanks,
Andrew
!980 2.0 Coupe - Owned since 1990
capriblu
« Reply #1 on: September 20, 2016, 09:45:01 PM »
Hi chaps,
Any thoughts / advice  Huh?
« Reply #2 on: September 21, 2016, 08:35:28 PM »
Which bush do you mean? One of the ones between the rack and the securing pieces?
capriblu
« Reply #3 on: September 22, 2016, 09:32:31 AM »
The hard plastic/nylon bush actually inside the rack at the n/s end.
« Reply #4 on: September 22, 2016, 05:31:50 PM »
I think this is what you mean.
http://353652584127257704.weebly.com/store/p535/TRW_Manual_Rack_Inner_Bush_PU_Copy.html
Mark states he has had these installed for some time now and all is well. I would have thought PU would be a good solution for this application, anyone else have any comments?
