November 21, 2024, 01:28:14 PM *
Pages: [1] 2
Author Topic: Radiator problem !  (Read 18437 times)
3cojones
Full Member
Lancia Beta Spider 1981
« on: November 27, 2015, 02:30:32 PM »
Hi All,
My Spider was overheating so took her to my garage who in turn found that the radiator was leaking from a small plug on the bottom tank. Under my instruction they sent it off to a Radiator Specialist (Brighton Radiators) who, a few days later, said that it was unrepairable as it was of plastic construction and not brass.   I previously thought that it had been recored by the previous owner but, in their opinion, it had not been as there was quite a bit of deterioration to the core and they thought it had just been "tarted up", painted etc.  It actually looks like a new rad ... AND I thought that all rads from this era were of plastic construction.
So, I googled a new or reconditioned rad last night and found very little .... well, in fact absolutely nothing.  Suppliers who used to sell them now list them as  discontinued.  Does anyone know of a supplier of either reconditioned or, even better, a new rad .... or does anyone had a very good rad for sale ?  Or, on the off chance, does anyone know of a fix for the leaking plug. That might buy me some time as the leak is quite slow, but ultimately the core letting the side down.
Any help would be really appreciated.
Regards,
« Reply #1 on: November 28, 2015, 09:16:43 AM »
What type/year is your car? Up to facelift 2 I thought all the rads were alloy?
You won't get a new one, your best bet is ebay, or one coming up on here.
I'm not sure, but surely there must be some sort of glue that will make at lest a temporary repair?
« Reply #2 on: November 28, 2015, 10:26:50 AM »
plastic? lost me somewhere there,AFAIK I thought the only Beta rads with plastic headers were the ones fitted to late vx/ ie models ( not all just some late examples) which have alluminium cores earlier ones were (i thought) all metal. pretty sure the earlier style can be recored perhaps you should try a different rad specialist?
ah are you just talking about the drain plug itself? i would have thought worst case you could just seal it permanently and drain by removing the  bottom hose instead not ldeal as i believe if i remember correctly the bottom pipe curves up so it wouldn't fully drain but surely it would do for now?
« Last Edit: November 28, 2015, 11:12:35 AM by rossocorsa » Logged
« Reply #3 on: November 28, 2015, 09:19:27 PM »
Some after market rads have plastic headers - mine does - but they must have been NLA years ago.
All the OE ones I've seen have been metal. The odds are very good that if you get one from a scrapper it will be possible to repair / recore it.
« Reply #4 on: November 28, 2015, 10:26:56 PM »
Agreed all spiders should have metal rads the rads with plastic headers were only fitted in production from late 1983
« Last Edit: November 29, 2015, 10:35:45 AM by rossocorsa » Logged
« Reply #5 on: November 29, 2015, 09:58:37 AM »
Today solution will be to chose a maker of alloy radiators and drive the car to them and have one made to the car. This is also an excellent opportunity to replace the old tired and dated fan and have the mounts made to suit the replacement. I have found the fans from Car Builder Solutions to be quiet powerful and reliable for my Montecarlo. I only had to add high amp waterproof connectors. Concept Racing near Hereford made my Montecarlo radiator after the group purchase alloy one failed after 12 years of service.
Have a look at the tuned car section on here I think Ian's Beta Coupe race car used a VW Scirroco radiator although I am not certain.
I hope this helps
3cojones
Full Member
« Reply #6 on: December 01, 2015, 08:27:15 PM »
Hi Neil,
Thanks for posting this.  I was quite surprised by this as I would have thought that refurbished rads would be available for the built-in-numbers Beta as opposed to the rarer Montecarlo, which are relatively easy to pick up.  Well that's how it is so I will have to look out for a s/h one and possibly recore that if needed.
Regards, Chris
3cojones
Full Member
« Reply #7 on: December 01, 2015, 08:38:53 PM »
Hi Rosocorsa,
Thanks for your advice on this.  Obviously a late VX/IE plastic header rad has been fitted to my Spider at some point.  I will take a closer look at the core once it's returned and see if it's worth permanently sealing the drain plug. It must be a drain plug - what else could it be ? - as I have not seen it as it was not easy to see fitted to the car in the pi**ing rain, and then the rad company just condemned it !
If it is indeed knackered I will have to find a s/h metal rad to be recored.  To be honest I was not very impressed by the radiator specialist - they were quite negative and defeatist, and passed one or two derogatory comments about Lancia/Fiats of this era ...
Thanks again,
3cojones
Full Member
« Reply #8 on: December 01, 2015, 08:43:27 PM »
Hi Stuart,
Thanks for posting your advice on how to fix my knackered rad.  Metal is obviously the way to go, and if I get one in decent shape I don't mind getting it re-cored at all.  There is one on eBay right now for £50 but unsure about it's condition ....
Regards, Chris
3cojones
Full Member
« Reply #9 on: December 01, 2015, 09:13:09 PM »
I hope this helps
Hi Eric,
Thank you your input on this, very much appreciated  Your option is obviously the ultimate way to go - A brand spanking new custom built rad would be great, and a bona fide long term solution. I can get a quote I suppose.  I like the idea of a new quieter smoother fan too.
It's funny you mention a Scirocco radiator as I've heard of it's use on Lancias before somewhere.
Regards,
gengis
« Reply #10 on: December 01, 2015, 09:28:19 PM »
When I took my 124 Spider radiator for repair/re-core at  East End Radiators, Glasgow.  I was totally surprised that he guessed it was off a 131, then quickly changed his mind to say Fiat 124.  He said that it was difficult to get the right size core material now, and to leave it with him couple of days.  Went back a couple of days later and it was completly repaired, we then went on to talk about his passion...Vespa's and Lambretta's.
He also guessed my Lancia Coupe petrol tank correctly, went I presented it for repair.
Good old school radiator repair shop.
1983 - Lancia Beta Coupe
1982 - Fiat 124 Spider
2012 - Alfa Romeo Mito
2011 - Fiat Fiorino
2006 - BMW F800st
« Reply #11 on: December 01, 2015, 11:59:00 PM »
Hi Rosocorsa,
Thanks again,
not sure if your rad will be a late one, the position and radiator style on late cars is a bit different even the hoses differ
« Reply #12 on: December 02, 2015, 09:52:26 AM »
I thought all Spyders in the UK were of the non IE/VX type engine and hence had the early style radiators?
Chris, on the VX/IE header, are you talking about the expansion tank?
lukasdeopalenica
Australia Australia
« Reply #13 on: December 02, 2015, 11:44:31 AM »
Both mine IEs have fully metal radiators (early and late model).
Subaru Outback 3.0R
3cojones
Full Member
« Reply #14 on: December 02, 2015, 02:13:51 PM »
Hi Neil. In answer to your original question my Spider is a 1981 facelift model.  The previous owner (targa2000) fortunately fitted a stainless steel expansion tank, renewed most of the hoses & jubilee clips and tested the thermostat (amongst a great deal of other new parts/improvements), so this rad leak is just unfortunate.
Regards, Chris
« Reply #15 on: December 02, 2015, 09:20:10 PM »
plastic/alloy rad is from about autumn 83 build date so approx last 12 months of production
3cojones
Full Member
« Reply #16 on: January 25, 2016, 02:00:57 AM »
Hi,
Wonder if you could help me - I've just bought a recored radiator for my Spider and the mounting brackets for the fan assembly are different to the ones on the old rad (I missed this fact when I compared pics before ordering, oops).  Each of the brackets has two smaller holes to take a couple of bolts, whereas my original has larger single holes.  I've attached a pic of the new rad (if it works ..)
Any ideas would be very welcome.
Thanks, Chris
JohnFol
« Reply #17 on: February 10, 2024, 02:27:01 PM »
I know this is an old thread, but I'm in need of a radiator. The plug that connects a pipe to expansion tank snapped off.
'79 carb spider and open to ideas..
« Last Edit: February 10, 2024, 03:11:53 PM by JohnFol » Logged
« Reply #18 on: February 10, 2024, 06:19:42 PM »
Hi John
I wonder if as temp fix you could bond in a brass or similar tube to get you going?
As you have probably found original ones are not available new (from what has been listed before) and so either find a second hand plastic tank one or if possible an old metal tank one and have it recored.
I also think there may be more than one thread on here about alternatives.
JohnFol
« Reply #19 on: March 06, 2024, 01:42:21 PM »
Tapped and glued a hollow M6 bolt to get me running again and then spotted top edge had a leak. Taken the plunge and have aluminum radiator on order. Now I need to work out if I need OAT, HOAT, G48, Paraflu 11, ethylhexanoate  or good old distilled water for the coolant
Pages: [1] 2
