November 25, 2024, 06:58:38 PM *
Author Topic: driveshaft support bearing spec  (Read 3265 times)
« on: November 02, 2015, 10:31:59 PM »
just in the middle of changing the shaft support bearing, I got the replacement bearing from Mark and it's C3 tolerance however the one that I've removed (and superficially seems original) is standard tolerance anyine know which it should be?
« Reply #1 on: November 02, 2015, 10:53:46 PM »
Alan,
C3 bearings are routinely used in applications where a standard one could be used - it's the other way around where you might run into problems. It's quite possible Lancia fitted both.
Stuart
« Reply #2 on: November 02, 2015, 10:58:42 PM »
Thanks I realise there's not a huge difference but you know I'm a terminal pedant
« Reply #3 on: November 03, 2015, 08:01:00 PM »
I has been noted on occasion, yes Wink
