November 29, 2024, 05:39:35 AM *
Pages: [1] 2
Author Topic: Back with a Beta  (Read 13729 times)
0 Members and 14 Guests are viewing this topic.
holmesgr001
« on: September 19, 2015, 07:24:33 PM »
I joined the group when I bought a 1975 beta coupe. I bought it unsighted and after I got it home realized its was too far gone(rust).
Good news is I have just bought a 1982 beta coupe 1600. This one I drove home.
More pics to come
« Reply #1 on: September 19, 2015, 09:10:22 PM »
Unusual colour is it a Seat built example?
holmesgr001
« Reply #2 on: September 20, 2015, 09:19:16 AM »
Hi Rossocorsa
Looks like the original colour was a metallic blue. Built by TAK in South Africa.  I will definitely have it re spayed. Undersided on the colour though. So far I have change the back left break caliper from the scrap lancia I had and am waiting for a mechanic to helicoil one of the plugs on the head, then I can take it for a run. It's been 22 years since my last drive in a Beta
holmesgr001
« Reply #3 on: September 20, 2015, 09:22:17 AM »
The only plate on it
« Reply #4 on: September 20, 2015, 11:25:45 AM »
Do you have a pic of the TAK chassis plate as well? Always interesting to see this quirky stuff. I think it will have been built or at least the CKD kit assembled well before 82.
I think the current colour is  good on a coupé even if not original
Ah I see your  note that this is the only plate, I think that will have been assembled in Italy. Build date is January 1981
« Last Edit: September 20, 2015, 11:34:07 AM by rossocorsa » Logged
holmesgr001
« Reply #5 on: September 20, 2015, 02:37:27 PM »
This is the plate off the older model beta.
TreviDash
« Reply #6 on: September 22, 2015, 12:37:13 PM »
I'm quite sure that is a Beta colour.  My father had a 1976 Berlina identical to the Autocar cover car that year
'84 Alfa 33 Gold Cloverleaf
'92 Daimler Six
holmesgr001
« Reply #7 on: September 23, 2015, 05:25:47 PM »
Ok so I've replaced a leaking water pump. But the compression test shows that there is something wrong with cylinder 2 and 3. Less than 2bar from each. I was kinda expecting that. So the question now is- do I rebuild the 1600 or the 2000 I have from my previously scrapped beta.
holmesgr001
« Reply #8 on: September 23, 2015, 05:28:47 PM »
Anyone out there replaced a 1600 with a 2000. Anything unexpected I should know about.
holmesgr001
« Reply #9 on: September 23, 2015, 05:34:05 PM »
holmesgr001
« Reply #10 on: September 23, 2015, 05:34:59 PM »
Pics of the interior
« Reply #11 on: September 23, 2015, 06:06:48 PM »
Only issue I can think of is final drive on 1600 is lower than 2000. So you may wish to change that as well to improve high speed cruising unless you want improved acceleration. P
holmesgr001
« Reply #12 on: September 23, 2015, 06:59:20 PM »
I have both gearboxes, so will use the box from the 2l
« Reply #13 on: September 23, 2015, 07:04:19 PM »
Pre face lift for that colour on a coupé
holmesgr001
« Reply #14 on: October 02, 2015, 05:27:20 AM »
So head off today, could this 1600 be a 2000?
holmesgr001
« Reply #15 on: October 02, 2015, 05:27:48 AM »
« Reply #16 on: October 02, 2015, 11:16:17 AM »
What does it say stamped above the oil filter?
« Reply #17 on: October 02, 2015, 01:36:40 PM »
with the head off simply measure the stroke
holmesgr001
« Reply #18 on: October 02, 2015, 03:07:35 PM »
Stroke is 90mm do definitely a 2000. The head is now at the engineer. Now it's to run around and try find gaskets
« Reply #19 on: October 02, 2015, 03:28:54 PM »
Plenty on Ebay over here usually, though maybe more difficult in SA?
Pages: [1] 2
