November 24, 2024, 06:41:48 PM *
Author Topic: Volumex water pump  (Read 5829 times)
mtulloch
« on: July 02, 2014, 08:17:37 PM »
Are the VX coolant water pumps identical to the other Betas as mine has a  noisey bearing and needs replaced?
Found this and it says that all are the same but I seem to remember somewhere that the VX pumps are uprated.
http://www.ebay.co.uk/itm/291180897664?ssPageName=STRK:MESINDXX:IT&_trksid=p3984.m1436.l2649
Also, are the bolts which hold the pulley on reverse threaded as I cannot shift them?
Thanks.
« Reply #1 on: July 02, 2014, 11:21:05 PM »
Pump has slightly deeper impeller, bolts are normal. You need graf pump pa168 or similar
http://www.ebay.co.uk/itm/Wasserpumpe-GRAF-PA168-/110931946431?pt=DE_Autoteile&hash=item19d40f2bbf
The bolts get rusted into the block but don't worry if they shear off they are not too difficult to remove once the pump is off
Oops read post wrong but same applies pulley bolts are normal thread
« Last Edit: July 03, 2014, 05:13:38 PM by rossocorsa » Logged
lukasdeopalenica
Australia Australia
« Reply #2 on: July 03, 2014, 08:44:32 AM »
I bought exactly the graf pa168 for spares (looks like OEM), hopefully will fit my i.e. engine, as blocks are rather identical.
regards
Subaru Outback 3.0R
mtulloch
« Reply #3 on: July 04, 2014, 07:14:00 AM »
Thanks lads. All bought & paid for.
andybeta
« Reply #4 on: July 04, 2014, 11:19:00 PM »
Go for a Monte water pump. Don't know why but this is what GC recommends. Eric may well be able to say why or even disagree.
« Reply #5 on: July 04, 2014, 11:21:29 PM »
The graf pump is Monte spec
lukasdeopalenica
Australia Australia
« Reply #6 on: July 28, 2016, 06:00:58 PM »
I know it is old thread but maybe it will be helpful for someone in the future. Now I had the chance to directly compare the two types of pumps. The only difference as it was said is the impeller height - 16mm for VX vs. 13mm for standard engines. Other details are exactly the same. That means a VX pump should improve cooling efficiency of standard engines, e.g. of mine  Cool
Subaru Outback 3.0R
« Reply #7 on: July 28, 2016, 06:04:06 PM »
A friend told me that he tried a vx pump in his ie and reckons it didn't fit which I found odd
