November 27, 2024, 08:48:17 PM *
Author Topic: Windscreen - when did they stop doing bonded?  (Read 7092 times)
« on: June 11, 2014, 12:55:21 PM »
Does anyone know when they switched the screen on the Spider from bonded type to rubber sealed and how I might tell the difference on a bare screen?
« Reply #1 on: June 11, 2014, 01:28:49 PM »
Hi Stuart
Did not realise there were any UK unbonded versions on Spider, I thought it came in after they had finished?
The difference will be in the p/n, but I had both next to each other and there is just a centimetre or so difference in the size, so I would measure them to make sure.
« Last Edit: June 11, 2014, 09:59:11 PM by peteracs » Logged
lukasdeopalenica
Australia Australia
« Reply #2 on: June 11, 2014, 03:58:54 PM »
They definitely differ in height. As far as I know the bonded windscreen, at least in coupes and HPEs is ca 1cm higher than the rubber seal mounted (68,5cm)
Subaru Outback 3.0R
« Reply #3 on: June 11, 2014, 07:21:11 PM »
Hi Stuart
Did not realise there were any UK unbounded versions on Spider, I thought it cam in after they had finished?
Also thought only the VX and ie models had the unbonded screen in the UK.
« Reply #4 on: June 11, 2014, 08:51:39 PM »
Will try to check the microfiche when I have time, not convinced that lancia would have fitted the rubber seal type to spiders as the bonded screen will assist rigidity never actually tried it but I was under the impression that the screens are interchangeable in that you could fit a screen with rubber to a bonded screen car(??) anyone know for certain?
« Reply #5 on: June 11, 2014, 09:58:27 PM »
I can confirm they are different sizes and hence would not be able to fit the later one to a bonded screen.
« Reply #6 on: June 11, 2014, 10:54:02 PM »
I thought the aperture was the same and the sealing method dictated the difference in screen size as the rubber seal is thicker ??
lukasdeopalenica
Australia Australia
« Reply #7 on: June 12, 2014, 07:37:25 AM »
That is the point.
Subaru Outback 3.0R
« Reply #8 on: June 12, 2014, 08:04:50 AM »
check this old thread http://www.betaboyz.myzen.co.uk/forum/index.php?topic=2100.0 for information that I found then on microfiche
« Reply #9 on: June 12, 2014, 08:52:11 AM »
Much appreciated
« Reply #10 on: June 12, 2014, 10:08:11 AM »
Following on from your comment in this thread what is the size of the fiches?
« Reply #11 on: June 27, 2014, 08:08:28 AM »
240mm x 180mm
apologies for slow reply been rather busy! I can check this again but last time I enquired only the normal smaller format fiche could be done
spud
« Reply #12 on: June 27, 2014, 01:02:45 PM »
My VX has a bonded screen from new.
Andrew.
Montecarlo S2 Spyder
HPE VX
Y10 GTi.e. x2
