November 24, 2024, 06:39:07 AM *
Author Topic: Heater matrix removal.  (Read 5463 times)
gengis
« on: January 15, 2014, 11:21:19 PM »
Hi guys,
Can the heater matrix be withdrawn by removing the spring clips that hold the bottom plastic enclosure to the top, or does the whole enclosure need to be removed.  I need to remove the matrix due to a coolant leak.
1983 - Lancia Beta Coupe
1982 - Fiat 124 Spider
2012 - Alfa Romeo Mito
2011 - Fiat Fiorino
2006 - BMW F800st
Ryan
« Reply #1 on: January 16, 2014, 03:48:33 AM »
In the later cars this can be done without the whole heater box removed.  It does involve removing the center console that surrounds the brake lever and small console that is beneath the hvac controls.  I just popped the clips and dropped the lower half down enough to extract the core.  I removed the vents below the controls to ease installation of the core
The biggest pain for me was taking out the small screws in the center console that are hidden by the lower seat cushions.  Lots easier if the seats are out of the car.  In fact, the whole job would be easier without the seats in the way in hindsight.
R
gengis
« Reply #2 on: January 16, 2014, 08:55:57 PM »
Thanks for that Ryan, that's what I thought...but wasn't sure if there were any hidden screws or cables.  Watch this space...!
2011 - Fiat Fiorino
2006 - BMW F800st
gengis
« Reply #3 on: January 19, 2014, 10:35:06 PM »
What a bear of a job!
The matrix wasn't leaking...just spillage from the valve.  while I was at it I also took out the main radiator for cleaning.  Filled both with petrol and steeped for an hour, then emptied out half the petrol then gave them a good shaking...repeated process twice.  Then cleaned with fresh water.  The main radiator was quite clean, but the heater matrix was restricted...probably 30% flow, which would explain a poor heater!  All built back up with fresh anti freeze, heater now working fine.
Thanks.
2011 - Fiat Fiorino
2006 - BMW F800st
