Sadly my fuel starvation problem seems to be not solved yet :/
What is worth mentioning after a long stay, for example after a night or couple of hours, the car drives smoothly and the pump is almost not hearable, but after about 10kms of not problematic drive the pump becomes noisy, (the sound it emits is variable and seems that changes with an engine load change) and eventually the engine stops. Then the restarted engine stops again just after a while. If the pause is longer the engine runs longer.
The pump was replaced (new Bosch unit) along with new fuel filter and the additional mesh filter before the pump was installed.
I suspect these reasons:
- pump (new but with failure or blocked by small particles not catched by the meshed filter (if it is possible)
- fuel pressure regulator
- fuel tank filter (no idea how to clean it as the opening is to small to put a hand in.
- fuel tank reservoir fills up slowly
Fuel lines seem to be ok and fuel flows out from a tank freely when the feed hose is disconnected from the fuel primary filter. I got already stuck with it
Any tips how to get it solved are welcome
