November 23, 2024, 08:11:47 AM *
Author Topic: Clutch Options  (Read 7645 times)
« on: June 17, 2013, 02:05:35 PM »
I've been doing a little research into clutch options for the standard 215mm clutch fitted to all Betas other than VX models
This probably isn't news to most but it might be of interest to newer members
As might be expected Fiat group used common parts where they could so there is some interchangeability. The following cars use a 215mm clutch that will fit the Beta (nb release bearings differ so you'll need a beta one but they're easy to get hold of):
Alfa 155 2.0 TS 8V
Fiat 131 2.0 (most T/C 131s too I understand)
Fiat Strada 125/130TC (presume 105tc too)
Lancia HF Turbo 1.6 (140lb ft as standard so a OE HF Turbo clutch might be an option too)
The chances are there are more - I'll add them as I find them
For reference the Helix cover and plate are 60-2182 & 70-1948  and the spline is 22.5x20T and is good for 179lb/ft with the organic plate
VXdeMayo
« Reply #1 on: June 17, 2013, 06:29:55 PM »
That's really handy Stuart,
I don't s'pose you could advise on suitable clutches for VX's as well could you?
I am going to need one when I put the decent engine back in.
Thanks in advance,
Chas. Smiley
« Reply #2 on: June 17, 2013, 09:02:45 PM »
chas
I went through the process of identifying vx compatible clutches a while ago, if I still have the notes somewhere I'll post it here however as the car has never ben reassembled I can't 100% guarantee that the parts will fit! With a bit of fishing around the right parts can be found quite cheap on ebay. For some reason the VX used the smaller 1600 release bearing possibly simply rationalisation of parts(?)
Alan
VXdeMayo
« Reply #3 on: June 18, 2013, 09:21:32 AM »
Dear Alan and rossocorsa,
thank you for any information you can find on the subject. That will be very helpful!
Best,
Chas. Smiley
« Reply #4 on: June 18, 2013, 09:33:48 AM »
Best,
Chas. Smiley
These are from previous threads, will add more if I find them.
http://www.betaboyz.myzen.co.uk/forum/index.php?topic=1161.0
http://www.betaboyz.myzen.co.uk/forum/index.php?topic=599.0
http://www.betaboyz.myzen.co.uk/forum/index.php?topic=41.0
« Last Edit: June 18, 2013, 09:36:50 AM by peteracs » Logged
« Reply #5 on: June 18, 2013, 07:12:13 PM »
Chas
An 8V Integrale Clutch will do very nicely for your VX using the Beta Release bearing. It is the correct 225mm diameter push type. NB the 16V Integrale clutch is larger AND a pull type assemble and it will not fit.
Enjoy
« Reply #6 on: June 18, 2013, 10:32:57 PM »
As Eric says the 8V Integrale unit will suit well and given that it's 185bhp you could use a standard one not an uprated one.
So far that exact same clutch only seems to be fitted to the Alfa 164 3.0 12V but there must be others. I'll keep looking
Edit:
Lancia Thema 16V Turbo
Some Fiat Croma TD
« Last Edit: June 19, 2013, 07:28:49 PM by HFStuart » Logged
mangocrazy
Graham Stewart
« Reply #7 on: June 18, 2013, 10:49:31 PM »
Alfa 155 2.0 TS 8V
What sort of power output would the HF Turbo 1.6 clutch tolerate? I'm planning on giving my Spider a makeover in the near to medium term, with a target of 150-160 bhp and I think an uprated clutch might be a smart idea...
2002 VW Transporter T4
2017 KTM Duke 690R
2008 Aprilia SL1000 Falco
1992 Ducati 888 SP3
1988 Honda VFR750F
1980 Yamaha RD350LC
« Reply #8 on: June 18, 2013, 11:48:39 PM »
Alfa 155 2.0 TS 8V
As Eric has noted elsewhere if I remember correctly, any uprated engine should use an uprated clutch, the standard one not being man enough to cope ( non VX ).
« Reply #9 on: June 19, 2013, 09:33:27 AM »
I think the question was more that would a standard HF Turbo clutch cope with the output of an uprated Beta engine.
Though the Helix part might be the same for both Beta and HF Turbo the OE spec of the HF Turbo one would almost certainly be higher to cope with the greater torque (141lb/ft vs 129lb/ft)
I had an HFie Turbo midly tweaked to 150bhp and 160lb/ft that was fine on a standard clutch. Since the limiting factor on the clutch is the torque and 160lb/ft is going some for a n/a two litre I'd suggest that an OE HF Turbo clutch would likely be more than adequate.
mangocrazy
Graham Stewart
« Reply #10 on: June 24, 2013, 08:45:49 PM »
Cheers Stuart, you translated my garbled enquiry correctly...  Grin
I'm guessing there's a notable price differential between an OE HF Turbo clutch and the Helix version...? As you say, if the OE HF Turbo clutch can cope with 160 lb/ft, then it should handle the more modest demands of a n/a motor with ease.
2017 KTM Duke 690R
1992 Ducati 888 SP3
1988 Honda VFR750F
1980 Yamaha RD350LC
andybeta
Full Member
« Reply #11 on: July 17, 2013, 06:00:07 PM »
Chas
Enjoy
IIRC this is what I fitted to my VX.
