November 29, 2024, 05:30:24 AM *
Author Topic: Carb Throttle linkage  (Read 6291 times)
smithymc
« on: October 10, 2012, 08:32:49 AM »
In taking off my carb to have it re-built, I noticed the 'odd' action of the cable/rod linkage fixed to the cam cover.
On closer inspection it appears that some form of bushing has effectively disintegrated over the 28 years my car has 'rested'.
Is it a case of making some new ones or are these available somewhere?
« Reply #1 on: October 10, 2012, 12:22:27 PM »
Do you have a picture of the linkage section where the bush should go?  I'll have a look at the parts book to see if it can be purchased individually and what the part number is.  Failing that I'll have a look at my Coupe and take the dimensions from the rubber bush on there so at least you have the measurements so you know hat to look for.
I would guess that it may be a case of buyinging a multi-pack of varying sizes (Most motor factors have a "Wot Nots" rack) and finding a suitible fit.  I assume its a Series 2 Face Lift with a Weber carb?
smithymc
« Reply #2 on: October 11, 2012, 10:15:15 AM »
Thanks Matt
I attach ( hopefully) a few photos which may clarify what I am on about.
« Reply #3 on: October 11, 2012, 11:25:09 AM »
I think the part number for these bushes are 82329228 - two are required. ( Item No. 5 in the picture )
I checked Felix's website in South Africa and he lists them as available (although they are call Bush White Linkage and listed for a Beta Sedan) but at £4.57 each it might be worth a punt.
Other than that your going to be looking for 2nd hand or an alternate part.
thecolonel
« Reply #4 on: October 11, 2012, 12:36:32 PM »
I havé this, sat on a shelf for years now.
« Reply #5 on: October 11, 2012, 12:40:03 PM »
Thats the fella !  And the bushes are white - so I think the PN is correct.  But Geoff's part looks like the way to go!
Yaay Geoff  Grin
smithymc
« Reply #6 on: October 11, 2012, 02:08:54 PM »
Fantastic. Is there a way to contact Geoff off-forum to buy the linkage ( if he wishes to sell it of course)?
I have seen reference to private messages, but I dont know how that works
smithymc
« Reply #7 on: October 11, 2012, 02:22:17 PM »
Ignore last message - found the icon thingy.
thecolonel
« Reply #8 on: October 11, 2012, 02:48:42 PM »
Hi Mark,
Sent you an email, and a message and the pidgeon has
just left as well.
Geoff
lanciamad
Marcus Robinson
« Reply #9 on: October 11, 2012, 04:20:39 PM »
You might want to try and source an original metal throttle linkage piece as well, (32, 9, 25,14 in Matts image) I wouldn't fancy keeping that plastic piece now you've got a good linkage/bushes from Geoff Smiley
2001 - Honda Civic Type R EP3
thecolonel
« Reply #10 on: October 11, 2012, 04:55:43 PM »
 Mark,
Complete piece in the post.
I may have the other pieces (32 etc) I'll have a look,
What's the length of the plastic link ?
Geoff
« Last Edit: October 11, 2012, 04:58:41 PM by thecolonel » Logged
smithymc
« Reply #11 on: November 28, 2012, 05:01:35 PM »
Geoff
Sorry its taken so long - the plastic link is about 90mm between centres. To be honest, something I could make a little shorter would make the action nicer.
thecolonel
« Reply #12 on: November 28, 2012, 08:41:45 PM »
These are the links I've found, lower one is fixed
length, upper is adjustable,  I can run a longer thread
if required.
