November 24, 2024, 01:46:58 AM *
Author Topic: Source of Studs for door card?  (Read 4263 times)
« on: October 07, 2012, 11:23:36 PM »
Hi All
Anyone have a suggestion for replacement studs to hold on the door card?
Not sure if the F/L cars have different ones, but looking for pre F/L.
« Reply #1 on: October 07, 2012, 11:31:13 PM »
Ah, should have looked a bit more as found post by Gerhard with discussion on these. Any alternative available in UK as ones in Portugal are a little expensive at over £1 each and I need two door cards worth....
targa2000
« Reply #2 on: October 08, 2012, 02:55:19 PM »
Refitted my door cards recently on my 1981 spider using new clips from Fiat, part no 14191280, around 49p each.
Hope this helps, Tim
« Reply #3 on: October 08, 2012, 03:50:43 PM »
Hi Tim
Thanks, will look them up.
lukasdeopalenica
Australia Australia
« Reply #4 on: October 09, 2012, 06:16:41 PM »
They are probably the same as used in fiats i.e. cinquecento, seicento etc. If so, there are alternative replacements in Poland for about 10p/piece.
Subaru Outback 3.0R
TonyLanciaBeta
« Reply #5 on: October 09, 2012, 11:07:40 PM »
a couple of years ago I bought the same clips (FIAT 14191280)
I remember having to remove the plastic inserts in the door to fit mine, as the diameter of the new clip was wider
1981 Beta Coupe 1600
2012 Ypsilon (daily)
Gerhard
« Reply #6 on: October 15, 2012, 11:48:12 AM »
Feedback on it. The locally sourced studs, lasted about a week. Problem is that when they gave up they also damaged the new card. So in hindsight, go for as close to the original as possible.
« Reply #7 on: December 12, 2012, 09:40:28 AM »
Just following up on this one.
I sourced the following clips which are pretty close to the originals and fit snugly into the holes in the doors. The head size is just a tad larger, but ok. The head to base height where the doorcard fits is pretty much the same.
10 off for £2.99, worth having a play with at least.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290648075250&ssPageName=ADME:L:OC:GB:3160
Seller is 227sparts
I will update when I get around to fitting the door card and see if I have the same issue as Gerhard.
