« Reply #1 on: September 02, 2012, 08:02:16 PM » |
Unfortunately, the VW dampers will not work on the Beta, there is not enough damper travel from lock to lock.
I have tried three different VW dampers, they all have 140mm of travel and the Beta requires 170mm of travel.
I am still looking for an alternative part, but have been busy with work, and preparing to emigrate permanently to France.
1981 2000 Coupe S2/FL 1976 1600 Coupe S1 2007 Ypsilon 1.3 Bi-Colori
« Reply #2 on: September 02, 2012, 08:05:24 PM » |
archigraphe
« Reply #3 on: September 02, 2012, 08:44:04 PM » |
Yes I've notice this item...
It seem to me , humm, a little high in price with the proposed postage cost.
But I conserve this announce in memory....
In another forum I read that the bmw serie 3 was equipped with damper it have a similar travel...
Information about?
« Reply #4 on: September 02, 2012, 08:51:26 PM » |
Expensive but if you really need one .........
« Reply #5 on: September 02, 2012, 09:23:39 PM » |
If you can tell me the model of BMW then I can research - but I have heard this before (that a BMW damper may be used) but I recall that it did not have enough travel.
I think it was maybe E30 / E34 possibly.
I have checked with Stabilus in Germany, the company who made the original Beta steering damper and I was told that they did not make anything suitable. Of course the person I spoke to may not have wanted to help me very much... I will continue to look.
But even New old Stock like the one on Ebay will be 30 years old... which means 30 year old seals!! So £50 and it might only last one month..who knows?
I would prefer something that was manufactured recently.
« Reply #6 on: September 02, 2012, 10:18:24 PM » |
My experience of modern after market parts is not that good the worst quality they've ever been , you are probably right that new old stock is a risk but at least it's exactly right and with old fashioned build quality........with unobtainium sometimes you have to take a risk As regards stabilus I would very much doubt that they would recommend anything they hadn't tested themselves so I suppose it is possible that there is something that could be adapted
archigraphe
« Reply #7 on: September 03, 2012, 01:44:54 PM » |
So as Mattnovat mentioned, the vw : beetle or combi have short travel.... For the BMW I'dont know what model exactly, and here in France the scrapyard are'nt today accessible to public.... For Lancia the dim of the damper : STABILUX 000493 51/88 E02 Length : (eye to end strut) 465mm Min Length : (eye to end strut) 305mm Travel : 165mm The BMW E21 , E30 Steering Damper seems to have this dim : Lenght : 459.5mm cylinder : 160mm Ref ; 32111118616 Stabilus online catalog present's different product the stab o shock HD 24 have near dimension as our damper : travel / stroke 200 mm Length 498 mm so Min lengthe : 298mm Strenght N 650, 1500, 5000 Ref 4212ZA, 4213ZW, and 4214ZR Looking after this Damper, I'm questionning renewing the engine Damper...
« Last Edit: September 03, 2012, 02:41:32 PM by archigraphe »
thecolonel
« Reply #8 on: September 03, 2012, 02:07:39 PM » |
What about the company that rebuild the gas struts for the rear tailgate, have they been approached to see of they can rebuild the steering dampers.
« Reply #9 on: September 03, 2012, 02:27:43 PM » |
Do you know the name of the company Geoff?
thecolonel
« Reply #10 on: September 03, 2012, 05:07:58 PM » |
Under - Members cars - Living with a Trevi, as far as I can remember Should come up under a search for " gas struts "
mtulloch
« Reply #11 on: September 03, 2012, 08:28:13 PM » |
I've got tailgate dampers on my VX made by GSE from Bedford. Telephone no. is 01234 843979.
« Reply #12 on: September 04, 2012, 11:24:38 AM » |
So whichever way this goes I don't think there is going to be a "cheap" solution to this.
1. Any non OEM part will need modification... i.e. Most likely TIG welded bush eyes to at least one end. A BMW part "might" work but it is £60 plus shipping, then requires modification so could be a an expensive "give it a try" effort and it may not work at the end!
2. Buy a NOS item and trust the seals (£50)
3. Refurbish the original. So far I cannot find a company that would do that but I am still looking into that.
« Reply #13 on: September 05, 2012, 10:04:43 PM » |
If I was needing one of these i'd go for the nos option the seals have not been exposed to light and will not be worn so ought to be worth the gamble
Sent from my MOMO11 bird using Tapatalk 2
millieman
« Reply #14 on: September 05, 2012, 10:28:03 PM » |
Hi are you after a manual rack damper.
« Reply #15 on: September 05, 2012, 10:54:44 PM » |
I am looking at a new alternative part that will replace the OEM version.
While there are the odd few NOS which could be purchased, at ever increasing cost, there are more Betas on the road than there are new original steering dampers. Personally I would not use second hand dampers as they are an unknown quantity and could pop their seals ten minutes after fitting, making the whole effort a waste of time & money.
My point being that if a readily available and cost effective alternative part can be found then this has better than having a failed steering damper fitted that is not performing the job it's designed for.
If we look at the recent engine damper group buy, there were 24 people took advantage and 32 sets were purchased, in total. I'm not normally a betting man but I'd bet strong money on the fact that there ain't 32 NOS original steering dampers out there.
Currently I know where there are three!
« Last Edit: September 06, 2012, 09:06:03 AM by MattNoVAT »
archigraphe
« Reply #16 on: September 06, 2012, 09:40:05 AM » |
Hi Matt,
Yesterday un mesured the effective travel on the manual rack....
And on the car from left to right, I mesured a total travel of the steering rack from 10cm....
So...this is less as the out fo car travel which are 16cm as you note precedently..
The vw combi damper have a compressed length of 30cm, and a decompressed length of 42.5, the travel is 12.5.
Its'look to be enough as the travel of the original beta damper.
Next week I hope to buy a std Damper to make adaptation fitting on our car.
« Reply #17 on: September 06, 2012, 09:46:47 AM » |
I have already purchased VW Kombi, VW Transporter and VW T2 steering dampers and none of these work! I can sell them to you if you want to try for yourself, but I spent two days trying different modifications..... none worked. You cannot obtain full right hand lock because the damper runs out of travel before the steering rack reaches the full extent of its travel, so the damper is definitely too short.
archigraphe
« Reply #18 on: September 28, 2012, 04:43:03 PM » |
Oups.....so I hadn't read your answer, and now I'm with a superb combi steering Damper... Curiously on my car ( a 84 shell now with a manual steering LHD) the original damper doesn't travel all the stroke.... The damper , I've just bought, Is shorter than the length of the original close : 26cm vs 27.5 cm... ANd fully open : (eye to eye) 39.5cm vs 44cm.... But in fact .... in situ, on the rack.... the real stroke of the damper is 10cm The real lenght needed by the damper is 37.5cm as can do the combi damper... After is the conversion of the eye into bolt... For your information, in the "fantastic manual you "dropboxed"... they were two damper from two manufacturer, Stabilus And Way-assauto the open lengtht of the way-assauto is shorter than the stabilus, 41,15 cm vs 43,05 cm... so just 1.5 cm close or open from the combi damper... I'm looking this week with my neighbour who are a weldering sculptor....
« Reply #19 on: June 22, 2013, 10:37:37 AM » |
