November 21, 2024, 03:57:21 PM *
Pages: 1 [2]
Author Topic: LSD for Beta coupe  (Read 23336 times)
archigraphe
« Reply #20 on: January 31, 2013, 02:14:45 PM »
This is a light LSD for vehicule with power less than 200 bhp.
The extra torque on the blocked wheel is 3mkg, as write to me the distributor.
I'm going to test this solution , in may certainly, on the new gearbox I would install on the Lancia .
I'write you comment on this installation and driveability.
75coupe
1975 Beta coupe 2L
« Reply #21 on: March 13, 2013, 12:05:55 PM »
hi does this diff have cones in it?
I have just had a similar setup made but it uses the springs to preload cones as per Borg Warner type LSD's. Under high input torque the cones try to push against their seats in the casing, effectively trying to lock the output shafts of the diff. Under low input torque the side gears reduce the amount of side thrust on these cones, so they can slip and act like more like an open diff.
here are some pics:
75coupe
1975 Beta coupe 2L
« Reply #22 on: March 13, 2013, 12:12:14 PM »
More pics  Wink
archigraphe
« Reply #23 on: April 08, 2013, 09:10:17 AM »
to 75coupe, Have you test this solution on your car?
On the net, I read this solution may damage seriously the gearbox, because of "inhabituel" usage of the  gearing and an accelerated wear of the teeth.
75coupe
1975 Beta coupe 2L
« Reply #24 on: April 10, 2013, 05:30:34 AM »
Hi I have not tested this yet, but the person who did it successfully ran this setup in a highly modified Fiat X1/9 Prototipo replica running a Beta 2 litre engine and gearbox.
I will update once I have tested it.
75coupe
1975 Beta coupe 2L
« Reply #25 on: November 23, 2013, 09:20:15 PM »
Dear All
I have now tested the diff on the road and it works very well. It has eliminated virtually all inside wheel spin when pulling out of tight corners - I can now use full throttle in 1st gear out of a junction, whereas before it would just turn the inside tyre into smoke.
As for how long it will last is anyone's guess, but as with al mods you had to expect greater wear & tear!
Will update once tested on the track....
archigraphe
« Reply #26 on: January 27, 2014, 03:56:00 PM »
Ok do you think this solution may be useful in rally ?
I think Yes.... but if the gearbox break It will hurt....
Have you test it on track ?
75coupe
1975 Beta coupe 2L
« Reply #27 on: January 29, 2014, 11:39:41 AM »
Hi Archie,
I will be testing the diff again soon with new Guy Croft 190BHP engine, so will let you know. I have a hillclimb to do end of February, so will update then.
Regards ian
archigraphe
« Reply #28 on: April 22, 2014, 04:56:40 PM »
Is there new about this solution?
75coupe
1975 Beta coupe 2L
« Reply #29 on: April 29, 2014, 07:02:37 AM »
Sorry Archigraphe only just installed my GC engine, will be testing on the track at the end of May, remind me after this if I have not responded, been too busy renovating the house!
HF Stinger
« Reply #30 on: November 17, 2016, 09:03:47 AM »
This subject has been in the forefront of my mind again and I found this thread.
Is there enough testing to give us a longterm type update?
« Reply #31 on: February 08, 2023, 05:23:02 PM »
Old thread revival warning!
Just noticed this on eBay - no connection to the seller!
https://www.ebay.co.uk/itm/255968156004?hash=item3b98e41964:g:omcAAOSwXf5j4q9e&amdata=enc%3AAQAHAAAAoGMLFg01%2BgsWr1mMiyj3KVtykSXrB3Q4gNb86q%2BJ3d8BSJidMkqYlTc8%2FkAtarORfAFIjN51Y6qQkhNas%2BbkzzSJYnygagFGMJU4VmKP7GwmwkJbGgUkHDKTnAPWX9ArwBjTNwH3LqotnVXcTPjfoQsSXRZ%2BYR5F60nDSPGDPdTq%2BrbQKGlt05KwNH505D%2FRQZT%2BSM7E5SBq%2BhnPqSXW%2Fac%3D%7Ctkp%3ABk9SR_779ZzGYQ
Not for me, I'm contemplating trying a Quaife differential for an Alfa Romeo 164 as I believe it'll fit the Beta gearbox...
Fiat Panda 100HP and now!
« Reply #32 on: February 09, 2023, 11:06:45 AM »
just curious but has anyone tried fitting a viscodrive unit from Dedra/Delta2/Thema/Fiatcoupe? they seemed to work pretty well back in the day?
« Reply #33 on: February 09, 2023, 12:09:31 PM »
I looked into this. You need a different diff (with the beta crown wheel fitted to it) and housing the one from the 16V Fiat Coupe Turbo works (it's essentially a Beta box) the viscous coupling then sits in the fixed part of the driveshaft. Perfectly dooable but not a straight swap.
« Reply #34 on: February 10, 2023, 02:11:53 PM »
Just to add that most viscous LSDs are now so old that they will have worn to the point of becoming open diffs and repair is not DIY.
Pages: 1 [2]
