November 26, 2024, 04:33:48 PM *
Author Topic: Tension bearing for Campbeltown  (Read 3518 times)
wheelies
Full Member
« on: May 23, 2012, 07:52:39 PM »
While fitting a cambelt to a 2l fl spider, the spring on the tension bearing back plate jumped out of it's locating hole. Has anyone got a simple method of replacing it against it own tension. Looking at it it could be a skinner knuckle job.
wheelies
Full Member
« Reply #1 on: May 23, 2012, 07:56:13 PM »
Sorry should have read cambelt .
Who said predicted texting was easy.
lanciamad
England England
Marcus Robinson
« Reply #2 on: May 23, 2012, 09:03:10 PM »
I've loosened it off slightly then used a bar or large screwdriver to prise the spring into the hole and then re-tighten.
2001 - Honda Civic Type R EP3
« Reply #3 on: May 23, 2012, 09:33:02 PM »
If you can then clamp a pair of mole grips onto it and use them. Saving that a very long blade screwdriver may help.
It's a little bit awkward with the engine in place though as you noted.
wheelies
Full Member
« Reply #4 on: May 25, 2012, 09:21:21 AM »
Thanks lads for your suggestions, I will try them over the week end.
Sorry I will not be at the 40th in Norfolk, even though I have said I will try and get there but I have just had an eye operation and walking around with a patch over one eye.
Hope you all enjoy yourselves, Norfolk is a beautiful place. The weather forecast is supposed to be fantastic.
Give my regards to Amanda for organising the event.
Regards
